查看: 1445|回复: 2
高人,显显吧,这个交点的问题在哪啊
发表于 2005-3-24 15:33:00 | 显示全部楼层 |阅读模式
Public Sub selectAtPoint() Dim selectionSet1 As AcadSelectionSet, Lastset As AcadSelectionSet
Dim pyline As AcadLWPolyline
Dim line1 As AcadLine
Dim intPoints As Variant
Dim Fdata(0) As Variant
Dim Ftype(0) As Integer
Dim i As Integer, j As Integer, k As Integer, m As Integer, n As Integer, p As Integer, q As Integer, r As Integer, s As Integer
Dim pointPt(0 To 8000) As Double
Dim str As String
Dim vSelectPoint As Variant, vSelectPoint1 As Variant
Dim selection As AcadSelectionSet
ThisDrawing.SendCommand "cmdecho" & vbCr & "0" & vbCr
On Error Resume Next
Set selectionSet1 = ThisDrawing.SelectionSets.Add("SS1")
If Err Then
Set selectionSet1 = ThisDrawing.SelectionSets("SS1")
selectionSet1.Delete
End If
Set selectionSet1 = ThisDrawing.PickfirstSelectionSet
If selectionSet1.Count = 0 Then
If Err Then Set selectionSet1 = ThisDrawing.SelectionSets.Add("SS1")
selectionSet1.Clear
selectionSet1.SelectOnScreen
End If
Set Lastset = ThisDrawing.SelectionSets.Add("SS2")
ThisDrawing.Utility.Prompt "请选择测线:"
Fdata(0) = "3"
Ftype(0) = 8
m = 0
For i = 0 To selectionSet1.Count - 1
Set line1 = selectionSet1.Item(i)
line1.Color = acGreen
line1.GetBoundingBox vSelectPoint, vSelectPoint1
Set selection = ThisDrawing.ActiveSelectionSet
selection.Select acSelectionSetCrossing, vSelectPoint, vSelectPoint1, Ftype, Fdata
For j = 0 To selection.Count - 1
Set pyline = selection.Item(j)
pyline.Color = acBlue
intPoints = line1.IntersectWith(pyline, acExtendNone)
If VarType(intPoints) <> vbEmpty Then
n = 0
For k = LBound(intPoints) To UBound(intPoints)
pointPt(m) = intPoints(n)
pointPt(m + 1) = intPoints(n + 1)
pointPt(m + 2) = intPoints(n + 2)
k = k + 2
m = m + 3
n = n + 3
Next
Else
MsgBox "无交点数据", , "IntersectWith Example"
End If
Next
Next end sub 为什么 intPoints 是空的呢,问题出在哪呢,pyline是些LWPolyline的等高线。
发表于 2005-3-24 17:50:00 | 显示全部楼层
等高线的Z轴是0么?
 楼主| 发表于 2005-3-24 21:05:00 | 显示全部楼层
全是0,可能是些什么问题呢,飞狐大哥!
GMT+8, 2025-5-4 22:07 , Processed in 0.161102 second(s), 23 queries , Gzip On.
