查看: 3522|回复: 11
用VBA做的工具条,如何通过菜单实现工具条的显示与隐藏,另在菜单条的旁边作个显示或
发表于 2005-3-26 15:12:00 | 显示全部楼层 |阅读模式
用VBA做的工具条,如何通过菜单实现工具条的显示与隐藏,另在菜单条的旁边作个显示或隐藏的标记???[br]用VBA做的工具条,如何通过菜单实现工具条的显示与隐藏,另在菜单条的旁边作个显示或隐藏的标记??? 我用AutoCAD2002 谢谢 lgc
发表于 2005-3-28 09:04:00 | 显示全部楼层
请问搂主大哥,你做的工具条上的工具栏图标放在什么位置,怎么引用自己的图标啊??
发表于 2005-3-28 14:21:00 | 显示全部楼层
这个问题我也困惑很久了,        帮 顶!!!
发表于 2005-3-28 16:39:00 | 显示全部楼层
Dim newToolBarSeparator As AcadToolbarItem
Dim SmallBitmapName(42) As String
Dim LargeBitmapName(42) As String
Set MenuGroupObject = ThisDrawing.Application.MenuGroups.Item(0)
Set ToolbarObject = MenuGroupObject.Toolbars.Add("测量菜单")
Dim Popen As String
Popen = Chr(3) + Chr(3) + Chr(95) + "open" + Chr(13)
Set ButtonObject(1) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "打开文件", "打开文件", Popen)
Dim Psave As String
Psave = Chr(3) + Chr(3) + Chr(95) + "qsave" + Chr(13)
Set ButtonObject(2) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "保存文件", "保存文件", Psave)
Dim Pprinter As String
Pprinter = Chr(3) + Chr(3) + Chr(95) + "plot" + Chr(13)
Set ButtonObject(3) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "打印文件", "打印文件", Pprinter)
Dim Pcut As String
Pcut = Chr(3) + Chr(3) + Chr(95) + "cutclip" + Chr(13)
Set ButtonObject(4) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "剪切", "剪切", Pcut)
Set newToolBarSeparator = ToolbarObject.AddSeparator(ToolbarObject.Count + 1)
Dim pCopy As String
pCopy = Chr(3) + Chr(3) + Chr(95) + "copyBase" + Chr(13)
Set ButtonObject(5) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "带基点复制", "带基点复制", pCopy)
Dim Ppaste As String
Ppaste = Chr(3) + Chr(3) + Chr(95) + "pasteclip" + Chr(13)
Set ButtonObject(6) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "粘贴", "粘贴", Ppaste)
Dim Pbreak As String
Pbreak = Chr(3) + Chr(3) + Chr(95) + "break" + Chr(13)
Set ButtonObject(7) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "打断", "打断", Pbreak)
Dim Ptrim As String
Ptrim = Chr(3) + Chr(3) + Chr(95) + "trim" + Chr(13)
Set ButtonObject(8) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "截断", "截断", Ptrim)
Dim Pextend As String
Pextend = Chr(3) + Chr(3) + Chr(95) + "extend" + Chr(13)
Set ButtonObject(9) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "延伸", "延伸", Pextend)
Dim Pmove As String
Pmove = Chr(3) + Chr(3) + Chr(95) + "move" + Chr(13)
Set ButtonObject(10) = ToolbarObject.AddToolbarButton(ToolbarObject.Count + 1, "移动", "移动", Pmove)
SmallBitmapName(1) = "C:\Program Files\AutoCAD 2004\New Folder\POpen.BMP"
SmallBitmapName(2) = "C:\Program Files\AutoCAD 2004\New Folder\Psave.BMP"
SmallBitmapName(3) = "C:\Program Files\AutoCAD 2004\New Folder\Pprinter.BMP"
SmallBitmapName(4) = "C:\Program Files\AutoCAD 2004\New Folder\Pcut.BMP"
SmallBitmapName(5) = "C:\Program Files\AutoCAD 2004\New Folder\Pcopy.BMP"
SmallBitmapName(6) = "C:\Program Files\AutoCAD 2004\New Folder\Ppaste.BMP"
SmallBitmapName(7) = "C:\Program Files\AutoCAD 2004\New Folder\Pdd.BMP"
SmallBitmapName(8) = "C:\Program Files\AutoCAD 2004\New Folder\Pcj.BMP"
SmallBitmapName(9) = "C:\Program Files\AutoCAD 2004\New Folder\Pys.BMP"
SmallBitmapName(10) = "C:\Program Files\AutoCAD 2004\New Folder\Pmove.BMP"
 楼主| 发表于 2005-3-29 12:23:00 | 显示全部楼层
谢谢朋友:
                                                 不过我还有个问题请教:
就是用菜单控制autcad自定义工具条的显示与隐藏,另在菜单条的旁边作个显示或隐藏的标记,比如工具条显示时,对应菜单左边打个对号,反之,隐藏时,对应菜单左边就没了对号?
                                                         谢谢
        lgc
发表于 2005-3-29 16:59:00 | 显示全部楼层
请问朋友:子定义的菜单项可以调用自定义的过程函数吗?快捷菜单如何制作?
发表于 2005-3-31 15:38:00 | 显示全部楼层
请问如何可以控制菜单项的可用性??
发表于 2005-4-3 09:35:00 | 显示全部楼层
如果让系统启动就自动加载呢? 但不能重复加载.我目前使用这种办法可以自动加载,但是每次在CAD启动以后,如果在不关闭CAD的情况下,再打开另一个文件的时候就会出现重复家载的错误. (command "-vbarun" "dots.dvb!dotsdesign.NewMenuItem")
(command "-vbarun" "dots.dvb!dotsdesign.NewMenuToolbar")
 楼主| 发表于 2005-4-3 09:57:00 | 显示全部楼层
谢谢kevinchan,
        我现在比较困惑的是:假如已加载的工具条被关闭后,怎么能让它通过菜单让它可见.我试了重复加载,但不管用.是不是得用:menutoolbar.visual实现呢?我实在想不出来!!!
        lgc
发表于 2005-4-4 21:09:00 | 显示全部楼层
在CAD的工具栏\自定义。。。,点击你的工具条名
GMT+8, 2025-6-6 22:16 , Processed in 0.207066 second(s), 24 queries , Gzip On.
