- 积分
- 842
- 明经币
- 个
- 注册时间
- 2004-6-12
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
从网上下载的曲线等分相连程序很好用,如上图所示,因我不会编程,恳求高手能否将程序修改成如下图所示增加一斜线连接,我不懂编程见笑了,如不行就增加一个补上斜线的程序也可以的,先谢谢了,原程序如下:
;rul = 画线等分两条曲线 v2 ;避开捕捉造成的错误画线. ;支持无关曲线起点终点. 根据点中曲线的位置画线.! 2004.1.7 ;
(defun c:rul ( / msp el1 el2 e1 e2 n m d1 d2 sd1 sd2 key m) (vl-load-com) (vl-cmdf ".undo" "be") (setq msp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) el1 (entsel "\n第一条曲线:") el2 (entsel "\n第二条曲线:") e1 (vlax-ename->vla-object (car el1)) e2 (vlax-ename->vla-object (car el2)) n (getint "\n等分数:") m n d1 (vlax-curve-getDistAtparam e1 (vlax-curve-getendparam e1)) d2 (vlax-curve-getDistAtparam e2 (vlax-curve-getendparam e2)) sd1 (vlax-curve-getDistAtpoint e1 (vlax-curve-getClosestPointTo e1 (cadr el1))) sd2 (vlax-curve-getDistAtpoint e2 (vlax-curve-getClosestPointTo e2 (cadr el2))) key (if (or (and (< (/ sd1 d1) 0.5 ) (< (/ sd2 d2) 0.5)) (and (> (/ sd1 d1) 0.5 ) (> (/ sd2 d2) 0.5))) T nil) ) (repeat (1+ n) (vla-addline msp (vlax-3d-point (vlax-curve-getPointAtDist e1 (* (/ d1 n) m))) (vlax-3d-point (vlax-curve-getPointAtDist e2 (* (/ d2 n) (if key m (- n m)))))) (setq m (1- m)) ) (vl-cmdf ".undo" "e") (princ) )
