 - ;;4楼程序还是差一个")"(defun C:XBR (/ OS OE SS VSS N I D LEN E OBJ E)
- (princ "\n等分打断线段") (defun *ERROR* (MSG)
- (setvar "osmode" OS)
- (vl-cmdf ".undo" "e")
- (setq *ERROR* OE)
- ) (vl-cmdf ".undo" "be")
- (princ "\n选择要等分的物件:")
- (setq OE *ERROR*
- OS (getvar "osmode")
- SS (ssget '((0 . "LINE,*POLYLINE,SPLINE,ARC")))
- (setvar "osmode" 0)
- (or (setq N (getint "\n定数等分<需定距等分/直接回车>:"))
- (setq D (getdist "\n指定线段长度:"))
- (setq I 0)
- (if SS
- (repeat (sslength SS)
- (setq E (ssname SS I))
- (setq
- LEN (vlax-curve-getdistatparam E (vlax-curve-getendparam E))
- (if N
- (setq D (/ LEN N)
- M N
- (setq M (1+ (fix (/ LEN D))))
- (repeat (1- M)
- (if (setq PT (vlax-curve-getpointatdist E D))
- (vl-cmdf ".break" (list E PT) PT)
- (setq E (entlast))
- (setq I (1+ I))
- (princ)
