查看: 2238|回复: 5
那位大虾能赐教一下用Lisp 程序修改文件夹属性?例如将文件夹改为只读或非只读,或
发表于 2005-3-31 13:30:00 | 显示全部楼层 |阅读模式
那位大虾能赐教一下用Lisp 程序修改文件夹属性?例如将文件夹改为只读或非只读,或隐含![br]那位大虾能赐教一下用Lisp 程序修改文件夹属性?例如将文件夹改为只读或非只读,或隐含!
发表于 2005-3-31 15:24:00 | 显示全部楼层
Use File System Object, get the folder object, then set/get the attributes property Normal 0 Normal file. No attributes are set.
ReadOnly 1 Read-only file. Attribute is read/write.
Hidden 2 Hidden file. Attribute is read/write.
System 4 System file. Attribute is read/write.
Volume 8 Disk drive volume label. Attribute is read-only.
Directory 16 Folder or directory. Attribute is read-only.
Archive 32 File has changed since last backup. Attribute is read/write.
Alias 1024 Link or shortcut. Attribute is read-only.
Compressed 2048 Compressed file. Attribute is read-only.
发表于 2005-3-31 15:29:00 | 显示全部楼层
加载DosLib6.1吧,其中的 dos_dirattrib 函数就是修改或设置文件夹属性的。更多内容可参看其帮助文件
 楼主| 发表于 2005-4-1 13:03:00 | 显示全部楼层
怎么得到File System Object,具体语法怎么写?请告知!谢谢!
发表于 2005-4-1 15:18:00 | 显示全部楼层
发表于 2005-4-6 17:32:00 | 显示全部楼层
shell 命令能够
GMT+8, 2024-11-17 10:55 , Processed in 0.160073 second(s), 26 queries , Gzip On.
