查看: 2047|回复: 3
如何将选择的pline用mline重绘
发表于 2005-4-2 17:11:00 | 显示全部楼层 |阅读模式
Sub tt() '本程序的作用是选择一个pline线。然后用mline线重新绘制(原pline保留) 'mline 对正样式是“无”都设置好了,直接调用即可 Dim px(200) As Double '处理N个点(不定)
Dim py(200) As Double
'Dim center(211) As Double
Dim ent As Object
' let the user select a block.
If (flgPickNested = True) Then
Debug.Print "错误"
Exit Sub
Else
Dim pt As Variant
ThisDrawing.Utility.GetEntity ent, pt
End If
var = ent.Coordinates
retCoord = ent.Coordinates
k = (UBound(retCoord) + 1) / 2 '记录pline顶点个数
For i = 0 To UBound(retCoord) Step 2
px(i / 2) = retCoord(i)
py(i / 2) = retCoord(i) Next i
ReDim center(2 * (k - 1) + 1) As Double
For i = 0 To k - 1
center(i) = px(i)
center(i + 1) = py(i)
'center(i + 2) = 0
MsgBox center(i) & " =" & center(i + 1)
Next i
Dim lll As AcadMLine
Set lll = ThisDrawing.ModelSpace.AddMLine(center)
ZoomAll
End Sub 程序始终出错 请各位大虾帮忙调试
发表于 2005-4-2 21:50:00 | 显示全部楼层
Sub tt() '±¾³ÌÐòµÄ×÷ÓÃÊÇÑ¡ÔñÒ»¸öplineÏß¡£È»ºóÓÃmlineÏßÖØÐ»æÖÆ£¨Ô­pline±£Áô£© 'mline ¶ÔÕýÑùʽÊÇ¡°ÎÞ¡±¶¼ÉèÖúÃÁË£¬Ö±½Óµ÷Óü´¿É Dim px() As Double '´¦ÀíN¸öµã£¨²»¶¨£©
Dim py() As Double
Dim center() As Double
Dim ent As Object
Debug.Print "´íÎó"
Exit Sub
Else
Dim pt As Variant
End If
k = (UBound(retCoord) + 1) / 2 '¼Ç¼pline¶¥µã¸öÊý ReDim px(k)
ReDim py(k)
py(i / 2) = retCoord(i + 1)
Next i
ReDim center(3 * k - 1)
For i = 0 To k - 1
center(3 * i) = px(i)
center(3 * i + 1) = py(i)
center(3 * i + 2) = 0#
MsgBox center(3 * i) & ", " & center(3 * i + 1) & ", " & center(3 * i + 2)
Next i
ZoomAll
End Sub
 楼主| 发表于 2005-4-2 23:43:00 | 显示全部楼层
对以上程序我做了一点改进 只要执行有误,那么就是在2,和3之间的事情 Sub tt() Do While 1
Dim ent As Object
Debug.Print "错误"
Exit Sub
Else
Dim pt As Variant
End If
k = (UBound(retCoord) + 1) / 3 '记录pline顶点个数
ReDim px(k - 1) As Double
ReDim py(k - 1) As Double For i = 0 To UBound(retCoord) Step 3
px(i / 3) = retCoord(i)
py(i / 3) = retCoord(i + 1) Next i
Dim m As Integer
Dim n As Integer
m = 0
n = 0
ReDim Center(3 * (k - 1) + 2) As Double
For i = 0 To k - 1 Center(i * 3) = px(i)
Center(i * 3 + 1) = py(i)
Center(i * 3 + 2) = 0
'MsgBox px(i) & "*" & py(i)
Next i
'For i = 0 To 2 * (k - 1) + 1
'MsgBox Center(i)
'Next i
Dim lwp As AcadMLine
Set lwp = ThisDrawing.ModelSpace.AddMLine(Center)
lwp.Update
picked = True
Loop
ErrHandle:
End Sub
新的问题又来了,我要在自动绘制前把mline的线间距调整一下。 如何用程序实现
发表于 2005-4-3 08:06:00 | 显示全部楼层
查查系统变量CMLJUST,CMLSCALE和CMLSTYLE
GMT+8, 2025-6-6 22:04 , Processed in 0.174456 second(s), 23 queries , Gzip On.
