查看: 1626|回复: 2
VISUAL LISP中的ActiveX技术
发表于 2002-11-18 18:19:00 | 显示全部楼层 |阅读模式
请教:
使用VISUAL LISP中的ActiveX技术设置不同标注样式时如何改变各种样式中标注的系统变量
 楼主| 发表于 2002-11-19 08:16:00 | 显示全部楼层
为什么没有人回答
发表于 2002-11-19 12:36:00 | 显示全部楼层
Sets the value of an AutoCAD system variable.
Signature
object.SetVariable Name, Value
Object        Document
The object or objects this method applies to.
Name        String; input-only
The name of the system variable to set.
Value        Variant; input-only
The new value for the specified system variable.
Remarks
When setting system variables, AutoCAD may require integers, text, or double values. Passing the wrong data type, for example, passing a variant of type double when an integer is required, will also generate an error. The easiest way to avoid this is to use one of the Cxxx functions, such as CInt(), to explicitly type your data before it is passed.
For a list of all AutoCAD system variables and their types, please refer to System Variables in the AutoCAD Command Reference.
GMT+8, 2025-2-22 02:21 , Processed in 0.180947 second(s), 25 queries , Gzip On.
