查看: 2051|回复: 6
问count的用法。
发表于 2005-4-8 19:53:00 | 显示全部楼层 |阅读模式
能用count获得自定义的选择集中项目的个数吗?
具体怎么样实现?
发表于 2005-4-8 21:20:00 | 显示全部楼层
ssetObj.Count
 楼主| 发表于 2005-4-8 21:47:00 | 显示全部楼层
Sub example_select()
On Error Resume Next
Dim myss As AcadSelectionSet
If Not IsNull(ThisDrawing.SelectionSets.Item("myss")) Then
Set myss = ThisDrawing.SelectionSets.Item("myss")
myss.detele
End If
Set myss = ThisDrawing.SelectionSets.Add("myss")
Dim mode As Integer
mode = acSelectionSetAll
myss.Select mode
Dim returnobj As Object
Dim re As Variant
ThisDrawing.Utility.GetEntity returnobj, "Ñ¡ÔñÒ»¸öͼÏñ:"
returnobj.color = acRed
returnobj.Update
startpoint = returnobj.startpoint
endpoint = returnobj.endpoint
re = returnobj.ObjectName
MsgBox "×ø±êÆðµã" & startpoint(0) & "," & startpoint(1) & "," & startpoint(2) & " ÖÕµã " & endpoint(0) & "," & endpoint(1) & "," & endpoint(2) & " id " & re
returnobj.color = acByLayer
returnobj.Update
myss.RemoveItems returnobj
MsgBox " ¸öÊý " & myss.count
End Sub 为什么运行后是3个,难道myss.RemoveItems returnobj没有用?
发表于 2005-4-8 21:57:00 | 显示全部楼层
returnobj必须为图元数组,而不是图元。
程序中GetEntity中的参数缺少,这样的结果是returnobj连图元都没返回
 楼主| 发表于 2005-4-8 21:59:00 | 显示全部楼层
可以帮我改一下让我看看吗?
光看书发现好多弄不懂啊。
发表于 2005-4-8 22:27:00 | 显示全部楼层
  1. Sub example_select()
  2.        On Error Resume Next
  3.
  4.        Dim myss As AcadSelectionSet
  5.        If Not IsNull(ThisDrawing.SelectionSets.Item("myss")) Then
  6.                Set myss = ThisDrawing.SelectionSets.Item("myss")
  7.                myss.detele
  8.        End If
  9.
  10.        Set myss = ThisDrawing.SelectionSets.Add("myss")
  11.
  12.        Dim mode As Integer
  13.        mode = acSelectionSetAll
  14.        myss.Select mode
  15.    MsgBox "选择集数量" & myss.Count
  16.
  17.        Dim returnobj(0) As Object
  18.        Dim returnpnt As Variant
  19.
  20.        Dim re As Variant
  21.        ThisDrawing.Utility.GetEntity returnobj(0), returnpnt, "选择直线:"
  22.
  23.        returnobj(0).color = acRed
  24.        returnobj(0).Update
  25.        Dim StartPoint, EndPoint
  26.        StartPoint = returnobj(0).StartPoint
  27.        EndPoint = returnobj(0).EndPoint
  28.        re = returnobj(0).ObjectName
  29.        MsgBox "起点 " & StartPoint(0) & "," & StartPoint(1) & "," & StartPoint(2) & "   终点 " & EndPoint(0) & "," & EndPoint(1) & "," & EndPoint(2) & "   id   " & re
  30.        returnobj(0).color = acByLayer
  31.        returnobj(0).Update
  32.
  33.        myss.RemoveItems returnobj
  34.
  35.
  36.    MsgBox "选择集数量" & myss.Count
  37.
  38.
  39. End Sub
 楼主| 发表于 2005-4-8 22:30:00 | 显示全部楼层
真是太感谢了,学二次开发三个多星期了。
发现看书好多东西弄不懂。
以后希望能够多多向您请教。
GMT+8, 2025-6-6 22:08 , Processed in 0.178452 second(s), 23 queries , Gzip On.
