查看: 1632|回复: 9
[LISP]
发表于 2005-4-9 09:26:00 | 显示全部楼层 |阅读模式
求救!
高手快来看那!
 楼主| 发表于 2005-4-9 09:29:00 | 显示全部楼层
  1. [QUOTE][CODE] 帮助修改一下,使得可可以运行!
复制代码
;;使用ActiveX创建多段线(二维)
;(vl-load-com)
;(setq *ModelSpace* (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object))));;初始化空间
(defun c:dd ()
     (setq HOLDECHO (getvar "cmdecho"))
     (setvar "cmdecho" 0)
     (setq n_s 10);;一行中有多少个点(根据实际情况确定)
     (setq w_e 2);;一列中有多少个点(根据实际情况确定)   ;;画河道横向线(垂直水流方向)
     (print "\nTo draw the y_oriented line")
   (textpage)
     (setq ss (getfiled "Open file" "d:\\" "dat" 8)
     s   t
     fn nil)
         (setq i 1)
         (setq k 1)
     (if ss
             (setq fn (open ss "r"))
             (print "\n Please waiting....")
             (while (<= i w_e)
                         (while (<= k n_s)
                                 (setq s (read-line fn))
                   (print s)
                                 (setq ps (cons (list (car(read s)) (car (cdr (read s)))) ps))
                   (print ps)
                   (setq k (1+ k))
                         (setq ps (reverse ps))
                         (draw_pline ps)
                         (setq i (1+ i))
               (close fn)
         (print "\n the file error! ")
   ;画河道纵向线(顺水流方向)
;       (setq j 1)
;       (print "\nTo draw the x_oriented line")
;       (setq ss (getfiled "Open file" "d:\\" "dat" 8)
;       s   t
;       fn nil)
;     (if ss
;         (progn
;             (setq fn (open ss "r"))
;             (print "\n Please waiting....")
;             (while (<= j w_e)
;                         (while s
;                               (setq s (read-line fn))
;                               (setq pps (cons (read s) pps))
;                         (setq pps (reverse pps))
;                         (draw_pline pps)
;                         (setq j (1+ j))
;                         (setq s t)
;               (close fn)
;         (print "\n the file error! ")
   (setvar "cmdecho" HOLDECHO)
(defun draw_pline (pointlist);;输入参数点表,形如:((x1 y1) (x2 y2) (x3 y3)...)
           (setq polypoints (apply 'append   pointlist)
           (setq VLADataPts (list->variantArray polypoints))
  ;;定义ActiveX方法生成多段线
           (setq pline (vla-addLightweightPolyline
           (vla-get-ModelSpace
                                       VLADataPts)
           (vla-put-closed pline vlax-false)
);给以双精度表示的二维点数组分配空间 (x1 y1 x2 y2 x3 y3...)->(x1 y1 x2 y3 x3 y3...)
  (defun list->variantArray (ptsList / arraySpace sArray);;
         (setq arraySpace (vlax-make-safearray
                                                     vlax-vbdouble ;元素类别
                                                   (cons 0
                                                   (- (length ptsList) 1); 数组维数
         (setq sArray (vlax-safearray-fill arraySpace ptsList))
         (vlax-make-variant sArray); 返回数组变体
[/CODE]
 楼主| 发表于 2005-4-9 09:31:00 | 显示全部楼层
怎么没人哪!
快来呀!
发表于 2005-4-9 10:21:00 | 显示全部楼层
你不给一个dat文件,别人怎么知道能不能运行?
不过这里丢了一个括号,你加上后,看看能不能运行先。。。
-&gt; (setq polypoints (apply 'append         pointlist))
 楼主| 发表于 2005-4-9 10:23:00 | 显示全部楼层
谢谢回复,我不知道怎么上转数据文件?
发表于 2005-4-9 10:24:00 | 显示全部楼层
不是急吗?那为什么不去试试我后面说的,如果可以了,还传什么数据啊
 楼主| 发表于 2005-4-9 10:24:00 | 显示全部楼层
真是一个)的问题:
 楼主| 发表于 2005-4-9 10:26:00 | 显示全部楼层
但是在屏幕上没有画出多段线来呀?
为什么呢?
 楼主| 发表于 2005-4-9 11:44:00 | 显示全部楼层
数据如下:(9442.00000000000 13523.0000000000)
(9602.44083730788 13518.2053431552)
(9773.21560137878 13517.7870245506)
(9930.95221281122 13514.9813567183)
(10121.9983028150 13511.1385546831)
(10310.3496636903 13547.5327119832)
(10467.3268423648 13584.4245220356)
(10644.8039968324 13623.8745115228)
(10789.2344696039 13683.3010218549)
(1004.7204471789 13748.4852401943) meflying可否调试一下?盼望回复!!!!
发表于 2005-4-9 14:39:00 | 显示全部楼层
这句改一下:
-&gt;(vla-put-closed pline :vlax-false)
如果看不见结果,可能图形不在屏幕中央,使用命令:ZOOM,E选项查看
GMT+8, 2025-2-19 07:10 , Processed in 0.152067 second(s), 25 queries , Gzip On.
