查看: 1366|回复: 2
有一个细节问题请教各位!
发表于 2005-4-10 14:42:00 | 显示全部楼层 |阅读模式
Dim oSpace As AcadBlock
With ThisDrawing
If .ActiveSpace = acModelSpace Then
Set oSpace = .ModelSpace
Else
Set oSpace = .PaperSpace
End If
End With 通过以上代码,现在oSpace中画图,适应于ModelSpace和PaperSpace, 但是,如果在PaperSpace中建一个视口,双击进入视口,这样,在视口里通过oSpace画的东西就会出现在PaperSpace中,而不在ModelSpace中,如何解决该问题?
发表于 2005-4-10 21:09:00 | 显示全部楼层
  1. Function GetActiveSpace() As AcadBlock
  2.        Dim objSpace As AcadBlock
  3.        With ThisDrawing
  4.        If .ActiveSpace = acModelSpace Then
  5.            Set objSpace = .ModelSpace
  6.        Else
  7.            If .MSpace = False Then
  8.                Set objSpace = .PaperSpace
  9.            Else
  10.                Set objSpace = .ModelSpace
  11.            End If
  12.        End If
  13.        End With
  14.        Set GetActiveSpace = objSpace
  15. End Function
  16. Sub GetSpaceSample()
  17. MsgBox "当前空间为: " & GetActiveSpace.Name, , "明经通道VBA示例"
  18. End Sub
 楼主| 发表于 2005-4-12 19:05:00 | 显示全部楼层
OK了,谢谢版主!
GMT+8, 2025-5-5 02:17 , Processed in 0.186019 second(s), 23 queries , Gzip On.
