查看: 1940|回复: 3
[求助]这个userform1窗口如何关掉
发表于 2005-4-10 22:08:00 | 显示全部楼层 |阅读模式
看下面这段: Private Sub CommandButton1_Click()
' This example creates a text object in model space.
' It then returns the text string for that object.
Dim dimobj As AcadDimension
Dim text As String
UserForm1.Showmodal = False
' Define the text object
ThisDrawing.Utility.GetEntity dimobj, basePnt, "Select an object"
'修改尺寸文字
text = dimobj.Measurement
UserForm1.Showmodal = True
'Print text
TextBox1.text = text
End Sub Private Sub CommandButton2_Click()
End End Sub
程序中 UserForm1.Showmodal = False错误,我的意思是当点CommandButton1时,进行选择标注尺寸,当尺寸选取后UserForm1.Showmodal =True,即窗口重新显示,不知道应该如何写?
发表于 2005-4-10 22:27:00 | 显示全部楼层
UserForm1.Show是显示
UserForm1.Hide是隐藏
 楼主| 发表于 2005-4-11 08:23:00 | 显示全部楼层
多谢mccad,这两句我自己也试出来了,但这个程序还是不能正常运行,我选择一个标注尺寸后,TextBox1.text 没的反应,还是空白的。指再指点一下,谢谢!
 楼主| 发表于 2005-4-11 11:09:00 | 显示全部楼层
问题已解决了!
GMT+8, 2025-5-5 02:30 , Processed in 0.189770 second(s), 23 queries , Gzip On.
