查看: 2390|回复: 6
[求助]如何加while语句
发表于 2005-4-12 17:10:00 | 显示全部楼层 |阅读模式
下面程序如何加while语句,我想循环选择圆弧,直到回车结束程序。谢谢! Sub arc_to_circle()
Dim cen As Variant
Dim radius As Single
Dim obj As AcadArc
Dim circleObj As AcadCircle ThisDrawing.Utility.GetEntity obj, point, "选择圆弧:"
cen = obj.Center
radius = obj.radius
obj.Delete
Set circleObj = ThisDrawing.ModelSpace.AddCircle(cen, radius)
End Sub
发表于 2005-4-12 21:16:00 | 显示全部楼层
Sub arc_to_circle()
On Error GoTo ErrHandle
Dim cen As Variant
Dim obj As AcadArc
Do While True
ThisDrawing.Utility.GetEntity obj, Point, "选择圆弧:"
cen = obj.Center
radius = obj.radius
obj.Delete
Loop
ErrHandle:
End Sub
 楼主| 发表于 2005-4-12 21:28:00 | 显示全部楼层
多谢版主指点,现在明白了!我刚开始接触VBA,所以有很多东西要学,还望你们多多指教!!
发表于 2005-4-12 21:55:00 | 显示全部楼层
Sub arc_to_circle()
Dim Centre As Variant
Dim BasePnt As Variant
Dim Rad As Double
Dim ReturnObj As AcadArc
Dim Descript As String
Do
On Error Resume Next
ThisDrawing.Utility.InitializeUserInput 1, " "
ThisDrawing.Utility.GetEntity ReturnObj, BasePnt, "选择圆弧<Enter结束>:"
If Err <> 0 Then
Descript = Err.Description
Err.Clear
If Descript = "类型不匹配" Then
MsgBox "不是圆弧!"
Else
If Descript = "用户输入的是关键字" Then
Exit Do
Else
MsgBox "没有选择!"
End If
End If
Else
Centre = ReturnObj.center
Rad = ReturnObj.radius
ReturnObj.Delete
Set circleObj = ThisDrawing.ModelSpace.AddCircle(Centre, Rad)
End If
Loop
End Sub
发表于 2005-4-12 21:58:00 | 显示全部楼层
我的建议,尽量少用Err.Description,而用Err.Number好些,这样可以避免不同语言版本的问题。
发表于 2005-4-12 22:01:00 | 显示全部楼层
谢谢明总指教,呵呵
发表于 2005-4-13 09:47:00 | 显示全部楼层
我见好多代码里面都用 On Error Resume Next 这样好不好的啊?什么情况下应该而且提倡用,什么情况下最好不要用 啊,谢谢!
GMT+8, 2025-7-5 04:25 , Processed in 0.181257 second(s), 23 queries , Gzip On.
