- 积分
- 829
- 明经币
- 个
- 注册时间
- 2005-3-24
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
Sub example_aaa() On Error Resume Next Dim myss As AcadSelectionSet If Not IsNull(ThisDrawing.SelectionSets.Item("myss")) Then Set myss = ThisDrawing.SelectionSets.Item("myss") myss.detele End If Set myss = ThisDrawing.SelectionSets.Add("myss") Dim mode As Integer mode = acSelectionSetAll myss.Select mode Dim layerobj As AcadLayer Set layerobj = ThisDrawing.Layers.Add("new") layerobj.color = acRed Dim returnobj As Object Dim returnpnt As Variant Dim re As Variant ThisDrawing.Utility.GetEntity returnobj, returnpnt, "选择图像:" MsgBox myss.count Dim StartPoint, EndPoint StartPoint = returnobj.StartPoint EndPoint = returnobj.EndPoint MsgBox "起点 " & StartPoint(0) & "," & StartPoint(1) & "," & StartPoint(2) & " 终点 " & EndPoint(0) & "," & EndPoint(1) & "," & EndPoint(2) & " name " & returnobj.ObjectName & " ID " & returnobj.ObjectID returnobj.Layer = "new" returnobj.Update Dim rees(0) As AcadEntity Set rees(0) = returnobj myss.RemoveItems rees MsgBox myss.count GoSub sts myss.Delete Exit Sub
sts: Dim k As Integer Dim i As Double Dim j As Double Dim count As Integer count = ThisDrawing.SelectionSets.myss.count ReDim mysss(count - 1) As AcadEntity For k = 0 To myss.count - 1 Set mysss(k) = ThisDrawing.SelectionSets.myss.Item(k) StartPoint = myss.Item(k).StartPoint EndPoint = myss.Item(k).EndPoint i = 3 j = 0 If StartPoint(i) = StartPoint(j) And StartPoint(i + 1) = StartPoint(j + 1) And StartPoint(i + 2) = StartPoint(j + 2) Then MsgBox "坐标起点" & EndPoint(j) & "," & EndPoint(j + 1) & "," & EndPoint(j + 2) & "终点" & StartPoint(j) & "," & StartPoint(j + 1) & "," & StartPoint(j + 2) & " name " & myss.Item(k).ObjectName & " ID " & myss.Item(k).ObjectID myss.Item(k).Layer = "new" i = i + 3 j = j + 3 myss.RemoveItems mysss MsgBox myss.count ElseIf EndPoint(i) = StartPoint(j) And EndPoint(i + 1) = StartPoint(j + 1) And EndPoint(i + 2) = StartPoint(j + 2) Then MsgBox "坐标起点" & EndPoint(j) & "," & EndPoint(j + 1) & "," & EndPoint(j + 2) & "终点" & StartPoint(j) & "," & StartPoint(j + 1) & "," & StartPoint(j + 2) & " name " & myss.Item(k).ObjectName & " ID " & myss.Item(k).ObjectID i = i + 3 j = j + 3 myss.Item(k).Layer = "new" myss.RemoveItems mysss MsgBox myss.count Else: MsgBox "no object" End If Next Return End Sub
要求:在一个封闭的图形中选择一个object,得出端点坐标,然后根据一端端点坐标得出相连object的两个端点坐标,直到得到封闭图像的所有object的端点坐标。(其实就是安一定方向得到端点坐标)
不知道为什么运行的不是按顺序得出端点坐标,请帮忙改一改。或者希望能够提出一个更好的按顺序得出端点坐标的方法。 |
