查看: 2903|回复: 4
三维CAD渲染怎么才能更真实! 不用渲染软件可以吗!?
发表于 2002-11-21 11:07:00 | 显示全部楼层 |阅读模式
发表于 2002-11-21 17:16:00 | 显示全部楼层
用命令PSQUALITY .
你可以用命令PSQUALITY        将值设置成10(最高的).其渲染质量最高.出使值为
0.5.
发表于 2002-11-21 19:16:00 | 显示全部楼层
CAD2002里初始值为75
发表于 2002-11-22 09:08:00 | 显示全部楼层
系统变量psquality的意义
以下文字摘自AutoCAD R14帮助文件
Type: Integer
Saved in: Registry
Initial value: 75
Controls the rendering quality of PostScript images and whether they are drawn as filled objects or as outlines.
  0        Turns off PostScript image generation
  <0        Sets the number of pixels per AutoCAD drawing unit for the PostScript resolution
  >0        Sets the number of pixels per drawing unit but uses the absolute value; causes AutoCAD to show the PostScript paths as outlines and does not fill them
发表于 2002-11-22 09:20:00 | 显示全部楼层
渲染对象的平滑度
系统变量facetres控制渲染对象的平滑度,取值范围在0.05-10,默认值为0.5。所以kkc先生上面的说法好象是搞错了。
GMT+8, 2025-5-14 13:52 , Processed in 0.172525 second(s), 23 queries , Gzip On.
