原程序是这样的:
飞哥再帮忙看看.
(defun c:#txt ( / oldcmd olderr ok txt_tb txt dcl_id sty fp nn ht pt txterr diag init wr_txt old_nn)
; 定义错误处理子程序
(defun txterr(s)
(if (and (/= s "console break")
(/= s "Function cancelled")
(/= s "quit / exit abort")
(princ (strcat "\nError:" s))
(if olderr (setq *error* olderr)); 恢复原系统设置
(if oldcmd (setvar "cmdecho" oldcmd))
; 对话框显示及驱动程序
(defun diag ( / i)
(if (> (setq dcl_id (load_dialog "#txt")) 0);加载对话框文件
(if (new_dialog "filetext" dcl [JX*6]id); 显示对话框
(progn start_list "what");将词组显示到列表框内
(mapcar 'add_list txt_tb
(end_list)
(setq i 1)
(repeat nn;点取词组分类项后的操作
(action_tile (strcat "c" (itoa i)) "(wr_txt)")
(setq i (1+ i))
(action_tile "what" "(setq i (atoi $value));选中词组
(setq txt (nth i txt_tb))(set_tile \"sel_ok\" txt)"
(action_tile "sel_ok" "(setq txt $value)")
(action_tile "accept" "(setq ok T)(done_dialog 1)(unload_dialog dcl_id)")
(action_tile "cancel" "(unload_dialog dcl_id)")
(start_dialog)
(prompt "\n无法显示对话框FILETEXT! 请检查对话框内容!")
(prompt "\n无法加载对话框文件#TXT.DCL! 请检查文件是否存在及路径是否正确!")
; 初始化程序, 把第1个分组项中的词组读入表txt_tb中
(defun init( / fname fp txt1)
(setq fname (findfile "$txt1.dat"))
(if (not fname)
(progn (princ "\n文件 $TXT1.DAT 不存在 !") (exit)) ; 文件不存在, 则退出
(setq fp (open fname "r"))
(setq txt_tb '())
(while (setq txt1 (read_line fp))
(setq txt_tb (cons txt1 txt_tb))
(close fp)
(setq txt_tb (reverse txt_tb))
(setq old_nn 1);记录索引号
; 更换列表框内词组显示内容
(defun wr_txt ( / fname fname1 fp txt1 i)
(setq i 1)
(while (<= i nn); 判别哪个词组项被点中
(if (= (get_tile (strcat "c" (itoa i))) "1")
(setq fname1 (strcat "$txt" (itoa i) ".dat")
i nn
(setq i (1+ i))
(if (setq fname (findfile fname1)); 查找文件是否存在
(setq old_nn (atoi (substr fname1 5)));记录索引号
(setq txt_tb '())
(while (setq txt1 (read_line fp));依次读出各词组
(close fp)
(start_list "what");在列表框内显示词组内容
(mapcar 'add_list txt_tb)
(end_list)
) ; progn
(alert (strcat "文件" fname1 "不存在!"))
(set_tile (strcat "c" (itoa old_nn)) "1");恢复原记录号
) ; if
; 主程序开始
(setq olderr *error*
*error* txterr
oldcmd (getvar "cmdecho")
(setvar "cmdecho" 0) ; 命令不回显
(setq nn 9) ; 词组分类数
(init) ; 初始化
(diag) ; 驱动对话框
(if (and ok txt)
(if (or (= (setq sty (tblsearch "STYLE" "HZ")) nil); "HZ"字型是否存在
(/= (cdr (assoc 40 sty)) 0) ; 字高是否为定值
(/=(getvar "TEXTSTYLE") "HZ"); 当前字型是否为"HZ"
(command "STYLE" "HZ" "txt,hztxt" 0 0.7 0 "n" "n") ; 设置"HZ"字型
(initget (+ 2 4));下面的输入值要求大于0
(setq ht (getreal "\n请输入字高<500>:"))
(if (not ht) (setq ht 500))
(setq pt (getpoint "\n请点取文字起点:"))
(command "text" pt ht 0 txt)
(setq *error* olderr);恢复原设置
// #txt.dcl
// 供#txt.lsp调用
filetext : dialog { // 对话框名称
label = "常用词组"; // 对话框标识
: row {
: boxed_column {
label = " 索 引 ";
: radio_button {
label = "常用术语"; // 多选一按钮
key = "c1";
value = "1"; // 初始值为"1", 表示选中
: radio_button {
label = "图纸名称";
key = "c2";
: radio_button {
label = "房间名称";
key = "c3";
: radio_button {
label = "卫生器具";
key = "c4";
: radio_button {
label = "管材配件";
key = "c5";
: radio_button {
label = "器材仪表";
key = "c6";
: radio_button {
label = "常用设备";
key = "c7";
: radio_button {
label = "构筑物";
key = "c8";
: radio_button {
label = "其它";
key = "c9";
: list_box {
label = "词组内容";
key = "what";
height = 15;
width = 26;
allow_accept = true; // 可双击鼠标选取
spacer_1;
: edit_box {// 编辑框
label = "所选词组:";
key = "sel_ok";
spacer_1;// 增加间距
ok_cancel;
