查看: 2878|回复: 5
[讨论]关于自动加载的acad.lsp.
发表于 2005-4-23 20:51:00 | 显示全部楼层 |阅读模式
本人不懂编程,(没入过门),从事连续冲压方面的工作,主要搞端子模. 在工作中接触到了不少的LSP,于是上网搜索,找到了www.mjtd.com, 得到了mccad,myflying,bdycad,spring,zzxxqq,秋枫(排名不分先后,不一一列举)等等大侠的无私帮助.在此表示感谢! 因为他们的帮助我东拼西凑,写了如下的自动加载外挂程序及菜单的acad.lsp 大家共同讨论下这个方面的话题. (defun Load_cht ()
(setq as (getenv "ACAD"))
(setenv
"ACAD"
(strcat as "E:\\stamping\\bmp;E:\\stamping\\lsp;E:\\stamping\\lib;"
);;;加载支持路径,学BDYCAD的,
(defun Load_stamping ()
(command "_menuload" "E:\\stamping\\stamping.mns")
(if (not (menugroup "stamping"))
(Load_stamping)
);;;加载菜单,学秋枫的
(menucmd "p11=+stamping.pop1")
(menucmd "p12=+stamping.pop2")
(menucmd "p13=+stamping.pop3")
(load "stamping.lsp")
(setq aler (strcat "三十功名尘与土,八千里路云和月."
"\n莫等闲,白了少年头,空悲切."
"\n欢迎使用Stamping CAD Soft."
"\n整理制作:MR.Andy Ding *^_^* *~_~* "
(alert aler)
);;;欢迎信息,忘了学谁的了,
(if (= (getvar "SYSCODEPAGE") "ANSI_950")
(Load_cht)
);;;根据间繁来加载不同的菜单.学ZZXXQQ的
 楼主| 发表于 2005-4-24 20:54:00 | 显示全部楼层
这节感觉不好: (if (= (getvar "SYSCODEPAGE") "ANSI_950")
(Load_cht)
) 哪位高手把它改成能判断英简繁,如果为系统为英文版那么就加载英文版的菜单.
发表于 2005-4-25 08:52:00 | 显示全部楼层
代码:
  1. (cond
  2.   (= (getvar "SYSCODEPAGE") "ANSI_950")   (Load_cht))
  3.   (= (getvar "SYSCODEPAGE") "ANSI_936")   (Load_chs))
  4.   (= (getvar "SYSCODEPAGE") "BIG5 Chinese") (Load_cht))
  5.   (= (getvar "SYSCODEPAGE") "GB2312 Chinese") (Load_chs))
  6.   (T (load_eng))
  7. )
复制代码
码页表:
  1. ASCII
  2. DOS932   Japan
  3. BIG5   Chinese(Taiwan, Hong Kong))
  4. KSC5601   Korean Wansung
  5. JOHAB     Korean Johab, not supported in R14
  6. ANSI_1250   Eastern European
  7. ANSI_1251   Cyrillic
  8. ANSI_1252   (US and Western Europe)
  9. GB2312 Chinese (PRC, Singapore)
  10. ANSI_1253   Greek
  11. ANSI_1254   Turkish
  12. ANSI_1255   Hebrew
  13. ANSI_1256   Arabic
  14. ANSI_1257   Baltic
  15. ANSI_874   Thai
  16. ANSI_932   Japan
  17. ANSI_936   Chinese (PRC, Singapore))
  18. ANSI_949   Korean
  19. ANSI_950   Chinese (Taiwan, Hong Kong)
  20. ANSI_1361   Korean Johab
复制代码
 楼主| 发表于 2005-4-27 08:55:00 | 显示全部楼层
多谢ZZXXQQ大侠指点,有问题再麻烦你!!!
发表于 2013-9-4 15:22:33 | 显示全部楼层
不错的代码,收藏一下,谢谢
发表于 2013-9-4 18:44:43 | 显示全部楼层
收藏了,谢谢楼主提供~~~~~~~~~~~~~
GMT+8, 2025-5-26 10:07 , Processed in 0.185997 second(s), 27 queries , Gzip On.
