查看: 1653|回复: 0
[求助]高手进来帮个忙
发表于 2005-5-9 13:40:00 | 显示全部楼层 |阅读模式
这是我模仿VB.NET在VBA里编的程序,但是运行后总是编译出错,请帮我改改。 Dim entity As AcadEntity
Sub 读取属性()
Me.danyuanhao.Text = ""
Me.tiji.Text = ""
Me.midu.Text = ""
Me.bire.Text = ""
Me.danweifarelv = ""
Me.wendushifou = ""
Me.wenduzhi = ""
Dim varattributes As Object
varattributes = entity.GetAttributes
Dim i As Integer
For i = LBound(varattributes) To UBound(varattributes)
Select Case varattributes(i).TagString
Case "单元号"
Me.danyuanhao.Text = varattribute(i).TextString
Case "体积"
Me.tiji.Text = varattribute(i).TextString
Case "密度"
Me.midu.Text = varattribute(i).TextString
Case "比热"
Me.bire.Text = varattribute(i).TextString
Case "单位发热率"
Me.danweifarelv.Text = varattribute(i).TextString
Case "温度:已 知(0)否(1)"
Me.wendushifou.Text = varattribute(i).TextString
Case "温度值"
Me.wenduzhi.Text = varattribute(i).TextString
End Select
Next
entity.Highlight (False)
End Sub
Private Sub chaxun1_Click()
On Error Resume Next
UserForm1.Hide
Dim basePnt As Object
ThisDrawing.Utility.GetEntity entity, basePnt, "选择实体"
If Err.Number <> 0 Then
Err.Clear
MsgBox "图形不是块参照或未选中"
Exit Sub
End If
entity.Highlight (True)
Call 读取属性
UserForm1.Show
End Sub
Private Sub end1_Click()
End
End Sub
Private Sub MultiPage1_Change() End Sub
Private Sub shuchu_Click()
Open "参数.doc" For Append Access Read Write As #1
'Print #1, "单元号 "; "体积 "; "密度 "; "比热 "; "单位发热率 "; "温度:已知(0)否(1) "; "温度值"
Print #1, danyuanhao.Text, tiji, midu, bire, danweifarelv, wendushifou, wenduzhi
Close #1
End Sub
-------------------------------------------------------------------------------------------------------------- Private Sub xuanzhe1_Click()
UserForm1.Hide
Err.Clear
Exit Sub
End If
Call 写入属性
userfom1.Show
End Sub
Sub 写入属性()
Dim blockobj As AcadBlock
Dim blockreference As AcadBlockReference
blockobj = ThisDrawing.Blocks.Add(entity.insertionPoint, "block" & entity.Handle)
Dim height As Double
Dim mode As Long
Dim prompt As String
Dim tag As String
Dim value As String
height = 1#
mode = acAttributeModeVerify
tag = "单元号"
prompt = tag
value = danyuanhao.Text
blockobj.AddAttribute height, mode, prompt, entity.insertionPoint, tag, value
tag = "体积"
prompt = tag
value = tiji.Text
tag = "密度"
prompt = tag
value = midu.Text
tag = "比热"
prompt = tag
value = bire.Text
tag = "单位发热率"
prompt = tag
value = danweifarelv.Text
tag = "温度:已知(0)否(1) "
prompt = tag
value = wendushifou.Text
tag = "温度值"
prompt = tag
value = wenduzhi.Text
blockreference = blockobj.InsertBlock(entity.insertionPoint, entity.Name, entity.XScaleFactor, entity.YScaleFactor, entity.ZScaleFactor, entity.Rotation)
ThisDrawing.ModelSpace.InsertBlock entity.insertionPoint, blockobj.Name, 1#, 1#, 1#, 0
entity.Delete
Exit Sub
errorhandler:
MsgBox ("数据输入错误或图形不是块参照")
End Sub
GMT+8, 2025-5-9 09:28 , Processed in 0.180027 second(s), 28 queries , Gzip On.
