查看: 1550|回复: 3
表如何转为字符窜
发表于 2005-5-10 13:29:00 | 显示全部楼层 |阅读模式
表如何转为字符窜
例:表(1 2 (3))=》字符窜 "(1 2 (3))"
发表于 2005-5-10 13:30:00 | 显示全部楼层
vl-prin1-to-string
 楼主| 发表于 2005-5-10 14:44:00 | 显示全部楼层
r14环境中如何实现
发表于 2005-5-10 17:12:00 | 显示全部楼层
  1. ;|
  2. ;;FOR R14----
  3. (setq LST '("a" "T1" 2 (3)))
  4. (LAI-PRIN1-TO-STRING LST)
  5. |;
  6. (defun LAI-PRIN1-TO-STRING (LST / FILE STR)
  7.    (setq FILE (open "c://TMP.txt" "w"))
  8.    (prin1 LST FILE)
  9.    (close FILE)
  10.    (setq FILE (open "c://TMP.txt" "r"))
  11.    (setq STR (read-line FILE))
  12.    (close FILE)
  13.    STR
  14. )
GMT+8, 2024-11-17 06:54 , Processed in 0.173602 second(s), 26 queries , Gzip On.
