- (defun c:load_fl (/ dcl_id jx y n1 n R r d a al rj)
- (setq dcl_id (load_dialog "c_fl.dcl"))
- (if (not (new_dialog "c_fl" dcl_id))
- (exit)
- (action_tile "begin" "(data_manage)")
- (start_dialog)
- (unload_dialog dcl_id)
- (if (< rd rx)
- (prompt "\n内孔半径大于外圆半径")
- (if (< rd rj)
- (prompt "\n节圆半径大于外圆半径")
- (if (> rx rj)
- (prompt "\n节圆半径小于内圆半径 ")
- (if (or (> (* 0.5 d) (- rd rj)) (> (* 0.5 d) (- rj rx)))
- (prompt "\螺栓孔太大 ")
- (draw1)
- (princ)
- (defun data_manage ()
- (setq x (atof (get_tile "cpx")))
- (setq y (atof (get_tile "cpy")))
- (setq cp (list x y))
- (setq rd (atof (get_tile "wb")))
- (setq rx (atof (get_tile "nb")))
- (setq rj (atof (get_tile "jb")))
- (setq d (atof (get_tile "kz")))
- (setq n1 (atoi (get_tile "ksh")))
- (setq n (float n1))
- (setq a1 (atof (get_tile "angle")))
- (setq a (* pi (/ a1 180)))
- (setq pt (polar cp a rj))
- (defun draw1 ()
- (command "circle" cp rd)
- (command "circle" cp rx)
- (command "circle" pt "D" d)
- (command "-array" "l" "" "p" cp n1 "" "y");_这儿是"l"不是"1"
- (command "layer" "m" 1 "c" 1 "" "")
- (command "circle" cp rj)
- (command "layer" "m" 0 "on" "" "")
