查看: 2516|回复: 1
AutoCAD 2004中的真彩色DXF组码:420
发表于 2002-11-30 08:58:00 | 显示全部楼层 |阅读模式
420
A 24-bit color value that should be dealt with in terms of bytes with values of 0 to 255. The lowest byte is the blue value, the middle byte is the green value, and the third byte is the red value. The top byte is always 0. The group code cannot be used by custom entities for their own data because the group code is reserved for AcDbEntity, class-level color data and AcDbEntity, class-level transparency data
24位真彩,低8位:蓝色,中8位:绿色,高8位:红色
如下(420 . 7990383):
Command: (entget (car (entsel)))
Select object: ((-1 . <Entity name: 7ef56e88>) (0 . "LINE") (330 . <Entity
name: 7ef56cf8>) (5 . "79") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"0") (62 . 91) (420 . 7990383) (100 . "AcDbLine") (10 296.01 140.244 0.0) (11
687.142 347.618 0.0) (210 0.0 0.0 1.0))
 楼主| 发表于 2002-11-30 09:06:00 | 显示全部楼层
AutoCAD 2004 VBA帮助中还没有指出真彩的实现方法
GMT+8, 2025-6-8 04:29 , Processed in 0.221577 second(s), 26 queries , Gzip On.
