查看: 1654|回复: 0
VB6实现的自动停靠窗体
发表于 2005-5-20 14:35:00 | 显示全部楼层 |阅读模式
1、新建EXE工程。
2、添加模块,键入以下代码:
'------------------- Module ---------------------------------------
' 2003-9-10
' 作者:任兀(DSclub)
'如果有问题
'请E-Mail:dsclub@hotmail.com
'----------- 说明 -----------------
'修改Private Const Margin As Long 的值可以改变吸附距离
'将本模块考入你的程序,然后在你的代码中写入Hook和Unhook即可
'---------------------------------------------------------------- Public Declare Function SystemParametersInfo Lib "user32.dll" Alias "SystemParametersInfoA" ( _
ByVal uAction As Long, _
ByVal uParam As Long, _
lpvParam As Any, _
ByVal fuWinIni As Long) As Long '去掉lpvParam的Byval修饰符才可以正常工作
Public Declare Function SetWindowLong Lib "user32.dll" Alias "SetWindowLongA" ( _
ByVal hwnd As Long, _
ByVal nIndex As Long, _
ByVal dwNewLong As Long) As Long
Public Declare Function GetWindowLong Lib "user32.dll" Alias "GetWindowLongA" ( _
ByVal nIndex As Long) As Long
Public Declare Function CallWindowProc Lib "user32.dll" Alias "CallWindowProcA" ( _
ByVal lpPrevWndFunc As Long, _
ByVal msg As Long, _
ByVal wParam As Long, _
ByVal lParam As Long) As Long
Public Declare Sub CopyMemory Lib "kernel32.dll" Alias "RtlMoveMemory" ( _
Destination As Any, _
Source As Any, _
ByVal Length As Long)
Public Type WINDOWPOS
hwnd As Long
hWndInsertAfter As Long
x As Long
y As Long
cx As Long
cy As Long
flags As Long
End Type Public Type RECT
Left As Long
Top As Long
Right As Long
Bottom As Long
End Type Public Const SPI_GETWORKAREA As Long = 48
Public Const GWL_WNDPROC As Long = -4
Public Const WM_WINDOWPOSCHANGING As Long = &H46 Global lpPrevWndProc As Long
Global gHW As Long
Private Const Margin As Long = 20 Public Sub Hook()
lpPrevWndProc = SetWindowLong(gHW, GWL_WNDPROC, AddressOf WindowProc)
End Sub Public Sub Unhook()
Dim temp As Long
temp = SetWindowLong(gHW, GWL_WNDPROC, lpPrevWndProc)
End Sub Function WindowProc(ByVal hw As Long, ByVal uMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Dim lpwndpos As WINDOWPOS
Dim WorkArea As RECT If uMsg = WM_WINDOWPOSCHANGING Then
SystemParametersInfo SPI_GETWORKAREA, 0, WorkArea, 0
CopyMemory lpwndpos, ByVal lParam, Len(lpwndpos)
If lpwndpos.x - WorkArea.Left < Margin And WorkArea.Left - lpwndpos.x < Margin Then lpwndpos.x = 0
If lpwndpos.y - WorkArea.Top < Margin And WorkArea.Top - lpwndpos.y < Margin Then lpwndpos.y = 0
If WorkArea.Right - lpwndpos.x - lpwndpos.cx < Margin And lpwndpos.x + lpwndpos.cx - WorkArea.Right < Margin Then lpwndpos.x = WorkArea.Right - lpwndpos.cx
If WorkArea.Bottom - lpwndpos.y - lpwndpos.cy < Margin And lpwndpos.y + lpwndpos.cy - WorkArea.Bottom < Margin Then lpwndpos.y = WorkArea.Bottom - lpwndpos.cy
CopyMemory ByVal lParam, lpwndpos, Len(lpwndpos)
End If
WindowProc = CallWindowProc(lpPrevWndProc, hw, uMsg, wParam, lParam)
End Function
3、在Form1的代码中键入:
Private Sub Form_Load()
gHW = Me.hwnd
Hook
End Sub Private Sub Form_Unload(Cancel As Integer)
Unhook
End Sub
4、运行。
GMT+8, 2025-10-12 04:29 , Processed in 0.159602 second(s), 23 queries , Gzip On.
