查看: 1614|回复: 1
教教~~~~~~~~
发表于 2005-5-25 22:40:00 | 显示全部楼层 |阅读模式
代码如下: Dim inblock As String
Dim layer As String
Dim direc As String
Dim blockname As String
Dim xsca As Integer
Dim ysca As Integer
Dim zsca As Integer
Dim xlas As Integer
Dim ylas As Integer
Dim zlas As Integer Dim excelapp As New Excel.Application
excelapp.Workbooks.Open "d:\cad.xls", , ReadOnly
With excelapp.ActiveWorkbook.Worksheets("Sheet1")
layer = .Range("f2")
direc = .Range("g2")
blockname = .Range("a2")
xsca = .Rang("h2")
ysca = .Range("i2")
zsca = .Range("j2")
xlas = .Range("k2")
ylas = .Range("l2")
zlas = .Range("m2") TextBox1.Text = blockname
TextBox3.Text = layer
TextBox4.Text = direc
TextBox5.Text = xsca
TextBox6.Text = ysca
TextBox7.Text = zsca
TextBox8.Text = xlas
TextBox9.Text = ylas
TextBox10.Text = zlas 调试时说 With excelapp.ActiveWorkbook.Worksheets("Sheet1") 下标越界 不解哦~~~~高手们教教!!
发表于 2005-5-26 11:59:00 | 显示全部楼层
d:\cad.xls文件中是不是有“sheet1”表。
GMT+8, 2025-5-5 10:17 , Processed in 0.137578 second(s), 23 queries , Gzip On.
