查看: 1909|回复: 2
[求助][LISP]關於尺寸換算的2個命令自動化
发表于 2005-5-28 13:39:00 | 显示全部楼层 |阅读模式
由於工作中经常接触各类图纸,公英制都有,经常需要换算尺寸,因此我编制了以下2个lisp命令来避免频繁的修改尺寸属性,DTI 是在公制图纸中将尺寸增加英制换算的命令,DTM 则是在英制图纸中将尺寸增加公制换算的命令,请哪位帮忙,将之合并成一个命令,自动判断当前尺寸的公制英制并追加相对应的换算单位,谢谢! (defun c:dti ()
(setvar "cmdecho" 0)
(command "dimoverride"
"DIMalt"
"1"
"dimaltF"
"0.03937007874015748031496062992126"
"dimaltu"
"7"
"dimapost"
"dimaltd"
"4"
(ssget)
(PRINC)
) (defun c:dtm ()
"DIMalt"
"1"
"dimaltu"
"2"
"dimaltd"
"1"
"dimaltF"
"25.4"
"DIMZIN"
"8"
"dimapost"
"mm"
(ssget)
(PRINC)
 楼主| 发表于 2005-6-1 07:57:00 | 显示全部楼层
怎麼沒人幫忙啊?
发表于 2005-6-1 08:42:00 | 显示全部楼层
加上IF 判决就解决了 , 题外话. 怎么楼主也和我一样用繁体操作系统啊. (DEFUN C:DTI()
(SETVAR "CMDECHO"0)
(IF (= (GETVAR "MEASUREMENT")1)
(VL-CMDF "dimoverride""DIMalt""1""dimaltF"
"dimaltu" "7""dimapost" "\"""dimaltd" "4" ""(ssget "X") "")
(command "dimoverride""DIMalt""1""dimaltu"
"2" "dimaltd""1" "dimaltF" "25.4" "DIMZIN" "8""dimapost" "mm" "" (ssget "X") "")
(SETVAR "CMDECHO"1)
(PRINC))
GMT+8, 2025-6-20 04:07 , Processed in 0.125933 second(s), 26 queries , Gzip On.
