查看: 2691|回复: 1
谁有能够批量修改文字的aotulisp程序
发表于 2002-12-11 11:28:00 | 显示全部楼层 |阅读模式
我曾经用过一个lisp小程序,能够批量修改文字,例如:将所有“abc”替换成“cba”,不知那位有这个程序,请指点,谢谢!
发表于 2002-12-11 14:20:00 | 显示全部楼层
If you are a 2002 user, 'Find & Replace' is perfect. If you are not...
try this little routine attached. I wrote it before I reallized there is a much better command in 2002. Be careful! it will find & replace all the matched strings without confirmation.
GMT+8, 2025-5-17 16:54 , Processed in 0.184290 second(s), 26 queries , Gzip On.
