查看: 1330|回复: 1
路过的高手帮忙改一下
发表于 2005-6-5 11:03:00 | 显示全部楼层 |阅读模式
大侠帮帮忙
我想把下面的程序改成如下:
命令:tt
指定第一点:
指定第二点或角度:
指定第二个角点或        [倒角(C)/标高(E)/圆角(F)/厚度(T)/宽度(W)]:
发表于 2005-6-5 12:25:00 | 显示全部楼层
  1. ;;;三点画斜向长方形:1、2点确定方向,3点确定对角线长度
  2. (defun c:test ()
  3.    (command "ucs" "")
  4.    (setq  pt1 (getpoint "\n第一点 : ")
  5.   pt2 (getpoint pt1 "\n第二点 : ")
  6.   ang (rad2ang (angle pt1 pt2))
  7.    )
  8.    (command "ucs" "n" pt1)
  9.    (command "ucs" "z" ang)
  10.    (setq pt3 (getcorner (list 0 0) "\n对角点 : "))
  11.    (command "rectang" (list 0 0) pt3)
  12.    (command "ucs" "")
  13.    (princ)
  14. )
GMT+8, 2024-11-17 11:24 , Processed in 0.174457 second(s), 26 queries , Gzip On.
