查看: 1710|回复: 1
[VBA]
发表于 2005-6-5 22:16:00 | 显示全部楼层 |阅读模式
我编有关旋转的程序运行不了,下面是我编的源程序,请高手指点. Sub addline1()
Dim lineobj As AcadLine
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double
pt1(0) = 1000: pt1(1) = 1000: pt1(2) = 0
pt2(0) = 1200: pt1(1) = 1000: pt1(2) = 0
Set lineobj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
End Sub
Sub rotateline()
ZoomAll
Dim basepoint(0 To 2) As Double
Dim rotationangle As Double
dim angle as double
basepoint(0) = pt1(0): basepoint(1) = pt1(1): basepoint(2) = pt1(2)
rotationangle = ThisDrawing.Utility.GetAngle(, "指定角度")
Angle = Angle *3.1415926/180
tbangle = Round(angle, 2)
rotationangle=tbangle
linobj.Rotate basepoint, rotationangle
lineobj.Update
End Sub
发表于 2005-6-5 22:50:00 | 显示全部楼层
第一个 pt2(0) = 1200: pt1(1) = 1000: pt1(2) = 0
看楼主的意思应该是 pt2(0) = 1200: pt2(1) = 1000: pt2(2) = 0
还有这个 rotationangle = ThisDrawing.Utility.GetAngle(, "指定角度")
angle = angle * 3.1415926 / 180
rotationangle = tbangle 后面三句删除。 getangle出来的是弧度,不需要转换了。 而且转换的也不对 还有 linobj.Rotate basepoint, rotationangle 应为 lineobj.Rotate basepoint, rotationangle 改正后可以运行 Sub rotateline()
ZoomAll
Dim angle As Double
'angle = angle * 3.1415926 / 180
'tbangle = Round(angle, 2)
'rotationangle = tbangle
lineobj.Update
End Sub
建议,变量定义中应有大写字母,输入时只用小写输入,程序会自动把相应字母变成大写,这样可以知道变量是否输入错误,如lineobj最好定义成lineObj
GMT+8, 2025-5-5 15:15 , Processed in 0.156431 second(s), 24 queries , Gzip On.
