查看: 1848|回复: 7
[求助]
发表于 2005-6-5 22:34:00 | 显示全部楼层 |阅读模式
Sub addline1()
Dim lineobj As AcadLine
Dim pt1(0 To 2) As Double, pt2(0 To 2) As Double
pt1(0) = 1000: pt1(1) = 1000: pt1(2) = 0
pt2(0) = 1200: pt1(1) = 1000: pt1(2) = 0
Set lineobj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
End Sub
Sub rotateline()
ZoomAll
Dim basepoint(0 To 2) As Double
Dim rotationangle As Double
dim angle as double
basepoint(0) = pt1(0): basepoint(1) = pt1(1): basepoint(2) = pt1(2)
rotationangle = ThisDrawing.Utility.GetAngle(, "指定角度")
Angle = Angle *3.1415926/180
tbangle = Round(angle, 2)
rotationangle=tbangle
linobj.Rotate basepoint, rotationangle
lineobj.Update
End Sub
发表于 2005-6-6 12:02:00 | 显示全部楼层
'Angle = Angle *3.1415926/180
'tbangle = Round(angle, 2)
'rotationangle=tbangle'上面3句不要啊!
'linobj.Rotate basepoint, rotationangle'此句linobj与前不一致啊!应该为lineobj
 楼主| 发表于 2005-6-6 19:11:00 | 显示全部楼层
此程序运行不出来 急盼高手指点,要不然毕不了业了,救命呀 Public Function getpoint(pt As Variant, x As Double, y As Double) As Variant
Dim pttarget(0 To 2) As Double
pttarget(0) = pt(0) + x: pttarget(1) = pt(1) + y: pttarget(2) = 0
getpoint = pttarget
Public Sub Testline()
Dim d1, d3, R1 As Double
Dim p1 As Variant
Dim p2, p3, p4, p5 As Variant
Dim ln1, ln2, ln3, ln4 As AcadLine
d1 = 15
R1 = 9
d3 = 4.1
p1(0) = 100: p1(1) = 100: p1(2) = 0
p2 = getpoint(p1, 0, d1 / 2)
p3 = getpoint(p1, 0, R1 - 0.5 - d3 / 2)
p4 = getpoint(p3, 0.5, 0.5)
p5 = getpoint(pt4, 0, d3)
Set ln1 = ThisDrawing.ModelSpace.addline(p1, p2)
Set ln2 = ThisDrawing.ModelSpace.addline(p2, p3)
Set ln3 = ThisDrawing.ModelSpace.addline(p3, p4)
Set ln4 = ThisDrawing.ModelSpace.addline(p4, p5)
End Sub
发表于 2005-6-6 20:27:00 | 显示全部楼层
Dim ln1, ln2, ln3, ln4 As AcadLine VB里没有这种写法,如果这么写表示ln1, ln2, ln3是变体,ln4 是AcadLine Public Sub Testline()
Dim d1 As Double, d3 As Double, R1 As Double
Dim p1(2) As Double
Dim p2, p3, p4, p5
Dim ln1 As AcadLine, ln2 As AcadLine, ln3 As AcadLine, ln4 As AcadLine
d1 = 15
R1 = 9
d3 = 4.1
p2 = getpoint(p1, 0#, d1 / 2)
p3 = getpoint(p1, 0#, R1 - 0.5 - d3 / 2)
p5 = getpoint(p4, 0#, d3)
Set ln1 = ThisDrawing.ModelSpace.AddLine(p1, p2)
Set ln2 = ThisDrawing.ModelSpace.AddLine(p2, p3)
Set ln3 = ThisDrawing.ModelSpace.AddLine(p3, p4)
Set ln4 = ThisDrawing.ModelSpace.AddLine(p4, p5)
End Sub
 楼主| 发表于 2005-6-8 16:19:00 | 显示全部楼层
[VBA]谢谢你,有了你的帮忙程序终于运行出来了,可以再帮一下吗,再行行好吧ok?
Sub offsetline()
Dim p1(0 To 2) As Double
Dim p2(0 To 2) As Double
p1(0) = 50: p1(1) = 50: p1(2) = 0
p2(0) = 60: p2(1) = 60: p2(2) = 0
Set lineobj = ThisDrawing.ModelSpace.AddLine(p1, p2)
lineobj.Closed = True
ZoomAll
Dim offsetobj As Variant
offsetobj = lineobj1.Offset(0.25)
End Sub
发表于 2005-6-8 20:20:00 | 显示全部楼层
Sub offsetline()
'去除该行lineobj.Closed = True
ZoomAll
offsetobj = lineobj.Offset(0.25) '该处原来为offsetobj 1= lineobj.Offset(0.25)
End Sub
 楼主| 发表于 2005-6-8 23:39:00 | 显示全部楼层
两条直线怎么延伸到相交,不相交怎么办帮修改一下程序
Sub lengthenline()
setlineobj1 = ThisDrawing.ModelSpace.AddLine(p1, p2)
lineobj1.Update
Dim p3(0 To 2) As Double
Dim p4(0 To 2) As Double
p3(0) = 40: p3(1) = 80: p3(2) = 0
p4(0) = 100: p4(1) = 80: p4(2) = 0
Set lineobj2 = ThisDrawing.ModelSpace.AddLine(p3, p4)
lineobj1.EndPoint = lineobj2
lineobj1.Update
End Sub
 楼主| 发表于 2005-6-8 23:41:00 | 显示全部楼层
[VBA]再帮一下忙嘛,帮改一下程序
Sub lengthenline()
lineobj1.Update
lineobj1.Update
End Sub
GMT+8, 2025-5-5 15:13 , Processed in 0.180153 second(s), 23 queries , Gzip On.
