查看: 2271|回复: 3
块属性的输出??
发表于 2005-6-7 13:11:00 | 显示全部楼层 |阅读模式
在输出块的属性时,用到"GetAttributes"方法,但"GetAttributes"又是由"AcadBlockReference"得到.
在我找到的例子中"AcadBlockReference"都是由插入块时得到.
问:1)AcadBlockReference是不是只能由插入块时得到??
2)如果块已存在(不需插入),该如何做??
谢谢!!
发表于 2005-6-7 22:44:00 | 显示全部楼层
AcadBlockReference不是只能由插入块时得到.
如果块已存在(不需插入),选择块(用鼠标)或搜索块名都可.
 楼主| 发表于 2005-6-8 18:04:00 | 显示全部楼层
块可以搜到,但属性该怎样显示呢?
发表于 2005-6-9 12:07:00 | 显示全部楼层
Dim basePnt As Variant
Dim elemod As Object
Dim pickblk As Object
On Error Resume Next
Me.Hide ThisDrawing.Utility.GetEntity returnObj, basePnt, "请选择属性块进行编辑"
Dim con()
Dim xxx As Integer
Dim yyy As Integer
Dim zzz As Integer
MSFlexGrid1.Clear
MSFlexGrid1.Rows = 1
MSFlexGrid1.TextMatrix(0, 1) = "标记"
MSFlexGrid1.TextMatrix(0, 2) = "提示"
MSFlexGrid1.TextMatrix(0, 3) = "值" 'temp = False If returnObj.ObjectName = "AcDbBlockReference" Then
varAttributes = returnObj.GetAttributes
ReDim con(UBound(varAttributes), 2)
For i = LBound(varAttributes) To UBound(varAttributes)
con(i, 0) = varAttributes(i).TagString
'con(i, 1) = elemod.PromptString
con(i, 2) = varAttributes(i).TextString
yyy = i
Next i
Set pickblk = ThisDrawing.Blocks(returnObj.Name)
For Each elemod In pickblk
If elemod.ObjectName = "AcDbAttributeDefinition" Then
For xxx = 0 To yyy
If con(xxx, 0) = elemod.TagString Then
con(xxx, 1) = elemod.PromptString
Exit For
End If
Next xxx
End If
Next elemod
MSFlexGrid1.Rows = yyy + 2
For i = 0 To yyy
MSFlexGrid1.Row = i + 1
MSFlexGrid1.Col = 1
MSFlexGrid1.Text = con(i, 0)
MSFlexGrid1.CellAlignment = 0
MSFlexGrid1.Col = 2
MSFlexGrid1.Text = con(i, 1)
MSFlexGrid1.Col = 3
MSFlexGrid1.Text = con(i, 2)
Next i Else MsgBox "你选择的不是图块,请从新选择", vbOKOnly, "提示"
End If Me.Show
GMT+8, 2025-5-5 15:25 , Processed in 0.144488 second(s), 23 queries , Gzip On.
