查看: 1871|回复: 5
对扩展数据作选择集?
发表于 2005-6-8 17:56:00 | 显示全部楼层 |阅读模式
用VBA对这样的扩展数据怎么作选择集?? Select object: ((-1 . <Entity name: 7ef57cb8>) (0 . "LINE") (330 . <Entity
name: 7ef55cb8>) (5 . "297") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"SXSS") (6 . "Continuous") (100 . "AcDbLine") (39 . 6.4606e+006) (10 66.5765
-59.6847 0.0) (11 67.3565 -53.7357 0.0) (210 0.0 0.0 1.0) (-3 ("DVXDATA" (1070
. 0) (1000 . "295")))
发表于 2005-6-8 20:14:00 | 显示全部楼层
ft(0) = 1001: fd(0) = "DVXDATA"
 楼主| 发表于 2005-6-8 21:49:00 | 显示全部楼层
reply
295能作为过滤条件吗?
发表于 2005-6-8 22:30:00 | 显示全部楼层
对于XData只能对1001码作为过滤条件,其他的不行
 楼主| 发表于 2005-6-8 23:47:00 | 显示全部楼层
谢谢lzh741206.
我在arx的帮助中也找到了这个结论: You can retrieve extended data for a particular application by specifying its name in a filter list, using the -3 group code. The acedSSGet() function returns entities with extended data registered to the specified name; acedSSGet() does not retrieve individual extended data items (with group codes in the range 1000–2000).
发表于 2005-6-9 09:37:00 | 显示全部楼层
有没有具体的例子让大家也学学。
GMT+8, 2025-5-5 15:14 , Processed in 0.165854 second(s), 23 queries , Gzip On.
