查看: 1958|回复: 3
PL线的ARC段的数据如何得到。
发表于 2002-12-13 08:28:00 | 显示全部楼层 |阅读模式
只看到陈老师那本书里写的DXF 42 为弓弦比, 不知该怎样用。 (90 度时为0.414  180度时为 1 真没搞懂表示什么),我想求这段ARC的长和半径。
发表于 2002-12-13 09:15:00 | 显示全部楼层
Online document shows...
Bulge (optional; default is 0). The bulge is the tangent of one fourth the included angle for an arc segment, made negative if the arc goes clockwise from the start point to the endpoint. A bulge of 0 indicates a straight segment, and a bulge of 1 is a semicircle
tan (90/4) = tan (22.5 deg) = 0.414
tan (180/4) = tan (45 deg) = 1
发表于 2002-12-13 13:08:00 | 显示全部楼层
http://www.mjtd.com/bbs/dispbbs.asp?boardID=3&RootID=6245&ID=6770
http://www.mjtd.com/bbs/dispbbs.asp?boardID=3&RootID=7938&ID=7961
 楼主| 发表于 2002-12-13 13:16:00 | 显示全部楼层
多谢,以前的帖子该多看看了。藏了这么多宝
GMT+8, 2025-1-15 23:34 , Processed in 0.176058 second(s), 25 queries , Gzip On.
