查看: 1923|回复: 0
获取打印机内文档的数量
发表于 2005-6-9 14:34:00 | 显示全部楼层 |阅读模式
'在模块中加入以下声明及模组: 'Constants Definition
Public Const CCHDEVICENAME = 32
Public Const CCHFORMNAME = 32
Public Const PRINTER_ACCESS_ADMINISTER = &H4
Public Const PRINTER_ACCESS_USE = &H8 'Types Definition
Public Type DEVMODE
dmDeviceName As String * CCHDEVICENAME
dmSpecVersion As Integer
dmDriverVersion As Integer
dmSize As Integer
dmDriverExtra As Integer
dmFields As Long
dmOrientation As Integer
dmPaperSize As Integer
dmPaperLength As Integer
dmPaperWidth As Integer
dmScale As Integer
dmCopies As Integer
dmDefaultSource As Integer
dmPrintQuality As Integer
dmColor As Integer
dmDuplex As Integer
dmYResolution As Integer
dmTTOption As Integer
dmCollate As Integer
dmFormName As String * CCHFORMNAME
dmUnusedPadding As Integer
dmBitsPerPel As Long
dmPelsWidth As Long
dmPelsHeight As Long
dmDisplayFlags As Long
dmDisplayFrequency As Long
End Type Public Type PRINTER_DEFAULTS
pDatatype As String
pDevMode As DEVMODE
DesiredAccess As Long
End Type 'API Declarations
Public Declare Function OpenPrinter Lib "winspool.drv" Alias "OpenPrinterA" (ByVal pPrinterName As String, phPrinter As Long, pDefault As PRINTER_DEFAULTS) As Long
Public Declare Function EnumJobs Lib "winspool.drv" Alias "EnumJobsA" (ByVal HPrinter As Long, ByVal FirstJob As Long, ByVal NoJobs As Long, ByVal Level As Long, pJob As Byte, ByVal cdBuf As Long, pcbNeeded As Long, pcReturned As Long) As Long Public Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long '取得指定的打印机,目前有多少 Jobs (最大值为 128)
'打印机的名称可以是 mapping 的网络路径名称,例如: "\\myserver\myprinter"
Function GetPrinterQueue(PrinterName As String) As Long
Dim PrinterStruct As PRINTER_DEFAULTS
Dim HPrinter As Long
Dim ret As Boolean
Dim JobStruct(0 To 127) As Byte
Dim pcbNeeded As Long
Dim pcReturned As Long
Dim TempByte As Byte '设定 Printer structure 初值
PrinterStruct.pDatatype = vbNullString
PrinterStruct.pDevMode.dmSize = Len(PrinterStruct.pDevMode)
PrinterStruct.DesiredAccess = PRINTER_ACCESS_USE
'取得打印机的 Handle
ret = OpenPrinter(PrinterName, HPrinter, PrinterStruct)
'取得打印机的 active jobs
ret = EnumJobs(HPrinter, 0, 127, 1, TempByte, 0, pcbNeeded, pcReturned)
If pcbNeeded = 0 Then
GetPrinterQueue = 0
Else
ret = EnumJobs(HPrinter, 0, 127, 1, JobStruct(0), pcbNeeded, pcbNeeded, pcReturned)
GetPrinterQueue = pcReturned
End If
'关闭打印机
ret = CloseHandle(HPrinter)
End Function Private Sub UserForm_Initialize()
'测试预设打印机的 Queue (Printer.DeviceName)
MsgBox "打印机中尚有 " & GetPrinterQueue(Printer.DeviceName) & " 份文件", 64, "提示"
End Sub
GMT+8, 2025-5-5 15:05 , Processed in 0.160838 second(s), 23 queries , Gzip On.
