查看: 1599|回复: 1
一个程序,请帮忙‘看看!
发表于 2005-6-10 10:20:00 | 显示全部楼层 |阅读模式
程序功能:对已知块进行属性输出。 程序: Public blkColl As AcadBlocks Public BlkObj As AcadBlock Public mspace As AcadModelSpace
Public count As Integer
Public I As Integer
Public elem As Object
Public subelem As Object Private Sub CommandButton1_Click() Set mspace = ThisDrawing.ModelSpace Set blkColl = ThisDrawing.Blocks count = blkColl.count ListBox1.Clear
For I = 0 To count - 1
ListBox1.AddItem blkColl.Item(I).Name
Next For Each elem In blkColl
If elem.Name = "DATA" Then
For Each subelem In elem
Label2.Caption = subelem.TagString
Label1.Caption = subelem.TextString
Label3.Caption = subelem.PromptString
Next
End If
Next End Sub 其中块名为“DATA”; 问题:subelem.TextString中只能显示先前的块属性,在cad中修改后的块属性却无法显示。 请帮我找找问题! 谢谢!
发表于 2005-6-10 10:40:00 | 显示全部楼层
Dim EntAtt As Variant
EntAtt = elem.GetAttributes Dim i For i=LBound(EntAtt ) to Ubound(EntAtt )
Label2.Caption = EntAtt(i) .TagString
Label1.Caption = EntAtt(i).TextString
Label3.Caption = EntAtt(i).PromptString
Next
GMT+8, 2025-5-5 15:04 , Processed in 0.178312 second(s), 24 queries , Gzip On.
