查看: 1837|回复: 1
这是ObjectDBX ActiveX services的注册程序,在windows98下没有问题,但Xp却不行...
发表于 2002-12-16 08:42:00 | 显示全部楼层 |阅读模式
这是ObjectDBX ActiveX services的注册程序,在windows98下没有问题,但windows Xp却不行,应如何在windows Xp下注册???
(vl-load-com)
(setq *OBJECTDBX* "ObjectDBX.AxDbDocument")
(defun REGSERVER (SERVER)
  (startapp
    "regsvr32.exe"
    (strcat "/s \"" SERVER "\"")
;; Get CLSID from ProgID
(defun GETCLASSID (PROGID)
  (vl-registry-read
    (strcat "HKEY_CLASSES_ROOT\\" PROGID "\\CLSID")
;; Register ObjectDBX ActiveX services,
;; if not already registered.
(defun REGISTEROBJECTDBX (/ SERVER)
  (cond
    ((GETCLASSID *OBJECTDBX*))
    ((not (setq SERVER (findfile "AxDb15.dll")))
     (alert "Error: Can't locate ObjectDBX Library (AxDb15.dll)")
    (t
     (REGSERVER SERVER)
     (or
       (alert
         "Error: Failed to register ObjectDBX ActiveX services."
 楼主| 发表于 2002-12-16 08:53:00 | 显示全部楼层
试出来了, 不烦麻烦各位了!!!
GMT+8, 2025-1-15 23:45 , Processed in 0.168354 second(s), 26 queries , Gzip On.
