可以试试这个“利用已有数据画线”的程序:![](source/plugin/imc_colorcode/images/loading.gif) - (load "xyp_lib");加载通用函数
- 如果已经下载xyp_lib并放到搜索路径下可以不再下载!
- 利用以下任何一种方式即可加载和运行通用函数内的所有子程序:
- 1.在acad.lsp中增加(load"xyp_lib")
- 2.在每个程序内增加(load"xyp_lib")
- 3.在command下,输入(load"xyp_lib")
- 4.在菜单.mnl中增加(load"xyp_lib")
- 通用函数下载地址:
- dispbbs.asp?boardID=3&ID=37554&page=1
- |; ;;;利用已有数据画线
- (defun c:test ()
- (cmdla0)
- (alert (strcat "数据格式 : "
- "\n点位号 X坐标 Y坐标 Z坐标"
- "\n..."
- "\n..."
- "\n..."
- (prompt "\n稍候 : ")
- (MKLA "建筑-红线" 1)
- (while (not
- (setq tn (getfiled "坐标数据文件(txt;dat;*)" "" "txt;dat;*" 2))
- (setq fle (findfile tn)
- pt-lst '()
- (if (not fle)
- (setq fle (getfiled "请选择坐标数据文件" "" "txt;dat;*" 8))
- (if fle
- (progn
- (setq fn (open fle "r")
- n 0
- (command "pline")
- (while (setq pt (read-line fn))
- (setq pt (cdr (read (strcat "(" pt ")")))
- pt-lst (cons pt pt-lst)
- n (1+ n)
- (command pt)
- (princ ".")
- (command "")
- (close fn)
- (jzhz);加载汉字
- (MKLA "坐标" 3)
- (mapcar '(lambda (#pt) (x_zb #pt)) pt-lst) ;标注顶点坐标
- (princ "共输入和标注 ")
- (princ n)
- (princ " 个坐标点!")
- (princ "\n未选择数据文件,退出")
- (cmdla1)
