查看: 1446|回复: 4
请教高手一个问题?
发表于 2005-6-19 11:10:00 | 显示全部楼层 |阅读模式
怎样判断线(LWPOLYLINE与SPLINE)上的任意点到终点或起点的距离?
发表于 2005-6-19 12:17:00 | 显示全部楼层
  1. (defun c:test ()
  2.    (setq  s1   (entsel "\n选择曲线上的点 : ")
  3.   e     (car s1)
  4.   pt   (cadr s1)
  5.   pt0 (osnap pt "near")
  6.    )
  7.    (setq  leng (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))
  8.   leng1     (vlax-curve-getDistAtPoint e pt0)
  9.   leng2     (- leng leng1)
  10.    )
  11.    (princ "\n总长 = ")
  12.    (princ leng)
  13.    (princ "\n分长1 = ")
  14.    (princ leng1)
  15.    (princ "\n分长2 = ")
  16.    (princ engl2)
  17.    (princ)
  18. )
 楼主| 发表于 2005-6-20 10:02:00 | 显示全部楼层
再问一下,如果分长1是指定的长度怎么求出点的坐标?
发表于 2005-6-28 14:36:00 | 显示全部楼层
可以用cad的定长等分啊,然后捕捉生成的点,不就可以满足你的要求了
发表于 2005-6-28 15:19:00 | 显示全部楼层
雷发表于2005-6-20 10:02:00再问一下,如果分长1是指定的长度怎么求出点的坐标?
  1. (defun c:test ()
  2.    (setq  s1   (entsel "\n选择曲线 : ")
  3.                    e     (vlax-ename->vla-object (car s1))
  4.                    len   (getreal "\n输入长度 : ")
  5.    )
  6.    (setq  pt (vlax-curve-getPointAtDist e   len))
  7. )
GMT+8, 2024-11-17 16:38 , Processed in 0.168369 second(s), 25 queries , Gzip On.
