查看: 2008|回复: 5
为什么我不能读取选择集的参数
发表于 2005-6-24 09:56:00 | 显示全部楼层 |阅读模式
Dim ssetObj As AcadSelectionSet
Dim FilterType(5) As Integer
Dim FilterData(5) As Variant
Dim element As AcadEntity
Dim qidian(2) As Double
Dim zhongdian(2) As Double Set ssetObj = ThisDrawing.SelectionSets.Add("ssetObj")
FilterType(0) = -4
FilterData(0) = "<or"
FilterType(2) = 8
FilterData(2) = "0"
FilterType(3) = 0
FilterData(3) = "Line"
FilterType(4) = 0
FilterData(4) = "Polyline"
FilterType(5) = -4
FilterData(5) = "or>" ssetObj.SelectOnScreen FilterType, FilterData
For Each element In ssetObj
If element.ObjectName = "AcDbLine" Or element.ObjectName = "AcDbPolyline" Then
element.color = acBlue
element.Update
qidian(0) = element.startPoint(0)
End If
Next 以上程序为了得到选择集直线的起点终点坐标 ,但是 qidian(0) = element.startPoint(0)我却得到报错的信息,用监视器监视element.startPoint是有参数的,我测试画的都是直线
发表于 2005-6-24 11:06:00 | 显示全部楼层
element.Color = acBlue
element.Update
temp = element.StartPoint
qidian(0) = temp(0)
End If
 楼主| 发表于 2005-6-24 11:35:00 | 显示全部楼层
temp改设为数组么,还是什么变量呢?
 楼主| 发表于 2005-6-24 11:41:00 | 显示全部楼层
我把temp设置为acadpoint
然后按你说的写,可是出的错误是
错误“91”,对变量或with块变量未设置
发表于 2005-6-24 12:04:00 | 显示全部楼层
dim temp
设置为变体
 楼主| 发表于 2005-6-24 14:58:00 | 显示全部楼层
谢谢!!!!
GMT+8, 2025-5-5 09:40 , Processed in 0.178564 second(s), 23 queries , Gzip On.
