查看: 1910|回复: 2
[VBA]求助:sendcommand 创建直线出现一些问题
发表于 2005-6-25 13:47:00 | 显示全部楼层 |阅读模式
我用 sendcommand 创建直线出现一些问题,请求各位大哥指点,程序如下 Sub myl()
Dim ptpick As Variant
Dim x As Double
Dim y As Double
Dim x1 As Double
Dim y1 As Double
ptpick = ThisDrawing.Utility.GetPoint(, "请选择第一点")
x = ptpick(0)
y = ptpick(1) ptpick = ThisDrawing.Utility.GetPoint(, "请选择下一点")
x1 = ptpick(0)
y1 = ptpick(1)
ThisDrawing.SendCommand ("_line" & vbCr & "x,y,0" & vbCr & "x1,y1,0" & vbCr)
End Sub 但是同样是差不多的代码,画圆的时候就可以 Sub mycircle()
Dim x As Double
Dim y As Double
Dim z As Double
x = ptpick(0)
y = ptpick(1)
z = 0
static r as Double
Dim returnString As String
returnString = ThisDrawing.Utility.GetString(False, "输入半径:")
If returnString = "" Then
r = r
Else
r = Val(returnString)
End If
ThisDrawing.SendCommand ("_Circle" & vbCr & "x, y, 0" & vbCr & r & vbCr)
End Sub 请教各位高手!
发表于 2005-6-25 14:17:00 | 显示全部楼层
reply
Sub myl()
Dim x As Double
Dim y As Double
Dim x1 As Double
Dim y1 As Double
x = ptpick(0)
x1 = ptpick(0)
y1 = ptpick(1) Dim mac As String
mac = "_line" & vbCr & VBA.str(x) & "," & VBA.str(y) & Chr(10) & VBA.str(x1) & "," & VBA.str(y1) & vbCr & vbCr
mac = VBA.Replace(mac, " ", "")
'MsgBox mac
ThisDrawing.SendCommand mac
End Sub
 楼主| 发表于 2005-6-25 20:49:00 | 显示全部楼层
谢谢版主!
GMT+8, 2025-5-5 09:09 , Processed in 0.142421 second(s), 23 queries , Gzip On.
