查看: 1440|回复: 0
[求助]ARX如何设置打印参数?
发表于 2005-7-2 16:36:00 | 显示全部楼层 |阅读模式
<RE class=Code>Sub Example_Plot()
    ' This example sends a plot of the current drawing
    ' to a file.
    ' Define the plot variable
    Dim currentPlot As ACADPlot
    Set currentPlot = ThisDrawing.Plot
    ' Define the output file name.
    ' Use "" to use the drawing name as the file name.
    ' Note: if the file name exists an error will be generated.
    Dim plotFileName As String
    plotFileName = "MyPlot"
    currentPlot.PlotToFile (plotFileName)
End Sub</PRE><RE class=Code>请问如何在ARX中编写类似的程序??</PRE>
GMT+8, 2025-9-13 05:12 , Processed in 0.166323 second(s), 23 queries , Gzip On.
