查看: 2095|回复: 1
为什么m_x已在ScaleDlg.h中定义过,而在ScaleDlg.cpp却不认可?
发表于 2002-12-20 10:34:00 | 显示全部楼层 |阅读模式
ScaleDlg.h文件内容:
#if !defined(AFX_SCALEDLG_H__883BC861_1336_11D7_A714_885276570047__INCLUDED_)
#define AFX_SCALEDLG_H__883BC861_1336_11D7_A714_885276570047__INCLUDED_
#if _MSC_VER > 1000
#pragma once
#endif // _MSC_VER > 1000
// ScaleDlg.h : header file
#include "resource.h"
#include <adslib.h>
#include <adui.h>
#include <acui.h>
// CScaleDlg dialog
class CScaleDlg : public CAcUiDialog
// Construction
public:
        CScaleDlg(CWnd* pParent = NULL);   // standard constructor
    void DisplayComboBox();
// Dialog Data
        //{{AFX_DATA(CScaleDlg)
        enum { IDD = IDD_DIALOG1 };
        CAcUiSymbolComboBox        m_x;
        CAcUiSymbolComboBox        m_y;
        CAcUiSymbolComboBox        m_p;
        //}}AFX_DATA
// Overrides
        // ClassWizard generated virtual function overrides
        //{{AFX_VIRTUAL(CScaleDlg)
        protected:
        virtual void DoDataExchange(CDataExchange* pDX);    // DDX/DDV support
        //}}AFX_VIRTUAL
// Implementation
protected:
        // Generated message map functions
        //{{AFX_MSG(CScaleDlg)
        virtual BOOL OnInitDialog();
        //}}AFX_MSG
        DECLARE_MESSAGE_MAP()
//{{AFX_INSERT_LOCATION}}
// Microsoft Visual C++ will insert additional declarations immediately before the previous line.
#endif // !defined(AFX_SCALEDLG_H__883BC861_1336_11D7_A714_885276570047__INCLUDED_)
ScaleDlg.cpp文件内容:
// ScaleDlg.cpp : implementation file
#include "StdAfx.h"
#include "ScaleDlg.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CScaleDlg dialog
CScaleDlg::CScaleDlg(CWnd* pParent /*=NULL*/)
        : CAcUiDialog(CScaleDlg::IDD, pParent)
        //{{AFX_DATA_INIT(CScaleDlg)
        //}}AFX_DATA_INIT
void CScaleDlg::DoDataExchange(CDataExchange* pDX)
        CAcUiDialog::DoDataExchange(pDX);
        //{{AFX_DATA_MAP(CScaleDlg)
        DDX_Control(pDX, IDC_COMBO_X, m_x);
        DDX_Control(pDX, IDC_COMBO_Y, m_y);
        DDX_Control(pDX, IDC_COMBO_P, m_p);
        //}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CScaleDlg, CAcUiDialog)
        //{{AFX_MSG_MAP(CScaleDlg)
        //}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CScaleDlg message handlers
BOOL CScaleDlg::OnInitDialog()
        CAcUiDialog::OnInitDialog();
        // TODO: Add extra initialization here
   DisplayComboBox();
   return TRUE;  // return TRUE unless you set the focus to a control
                      // EXCEPTION: OCX Property Pages should return FALSE
m_x.InsertString(-1,"good");
编译出现:
d:\LX\scale\ScaleDlg.cpp(55) : error C2065: 'm_x' : undeclared identifier
d:\LX\scale\ScaleDlg.cpp(55) : error C2228: left of '.InsertString' must have class/struct/union type
这是为什么?为什么m_x已经在ScaleDlg.h文件中定义过,而在ScaleDlg.cpp的
中,却不认可?
请各位高手帮助一下,谢谢!
e_mail:msd0819@mail.dlptt.ln.cn
发表于 2002-12-20 10:38:00 | 显示全部楼层
你的程序中
应为
void CScaleDlg::DisplayComboBox()
就行了。
GMT+8, 2025-5-1 14:40 , Processed in 0.143418 second(s), 24 queries , Gzip On.
