查看: 12714|回复: 29
这是我写的一个画标高的程序,大家来看看啊。
发表于 2002-12-22 13:56:00 | 显示全部楼层 |阅读模式
这是对话框:
bg : dialog {
   label = "标高标注设置 <作者:张越 2000.6.12>";
     : column {
          : row {
          : boxed_column {
             label = "基准点:";
            : button {
               label = "基准点:〈";
               key = "pick";
           : edit_box {
               label = "起始标高:";
               key = "ssbg";
         : boxed_column {
         label = "标高值:";
          fixed_width = true ;
            : toggle {
               label = "手工输入标高值";
                 key = "yn";
            : edit_box {
            label = "标高值:";
            is_enabled = false;
            key = "bgz";
            : row {
             : boxed_column {
              label = "比例:";
            : edit_box {
              label = "作图比例:";
              key = "scale1";
              value = "100";
            : edit_box {
              label = "图纸比例:";
              key = "scale2";
              value = "100";
            : boxed_column {
            label = "标高式样:";
          // fixed_width = true ;
            : toggle {
               label = "画出引出线";
               key = "yt";
            : toggle {
               label = "使之与基线平行";
          //fixed_width = true ;
               key = "ym";
         : boxed_column {
         label = "选择字型:";
            : popup_list {
              label = "选择字型:";
              key = "styl";
               fixed_height = true;
            : concatenation {
                : text_part {
                    label = "当前字型:";
                    width = 10;
                 : text_part {
                   key = "csty";
                   width = 10;
       spacer;
      : row {
          ok_cancel;
          : button {
             label = "说明(&H)";
              fixed_width = true;
              key = "shuoming";
          spacer;
shuoming : dialog{
      label= "简要说明";
             : column {
                : button  {
                   label = "基准点";
                   key = "shuom1";
                : button  {
                   label = "手工输入标高";
                   key = "shuom2";
                : button  {
                   label = "作图比例";
                   key = "shuom3";
                : button  {
                   label = "图纸比例";
                   key = "shuom4";
                : button  {
                   label = "选择字型";
                   key = "shuom5";
                : button  {
                   label = "使之与基线平行";
                   key = "shuom6";
                ok_only;
shuom1 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "基准点说明";
        fixed_widht = true;
        : text {
           label = " 用于设置基准标高值的位置。";
     ok_only;
shuom2 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "手工标高输入说明";
        fixed_widht = true;
        : text {
           label = " 打开时程序将提示你输入标高值。";
        : text {
           label = " 有记忆功能。";
        : text {
           label = " 关闭时程序将直接画出插入点的标高。";
     ok_only;
shuom3 : dialog {
      label= "简要说明";
     : boxed_column {
      label= "作图比例说明";
        fixed_widht = true;
        : text {
           label = " 即你所要进行标注的大样图或立面图的比例。";
     ok_only;
shuom4 : dialog {
      label= "简要说明";
     : boxed_column {
        label= "图纸比例说明";
        fixed_widht = true;
        : text {
           label = " 即出图时所用的比例。";
     ok_only;
shuom5 : dialog {
label= "简要说明";
: boxed_column {
label= "选择字型说明";
fixed_widht = true;
: text {
label = " 即画标高时所用的字型。";
ok_only;
shuom6 : dialog {
label= "简要说明";
: boxed_column {
label= "与基线平行说明";
fixed_widht = true;
: text {
label = " 用于水暖作图时,将标高方向同管道。";
ok_only;
这是主程序:
;;;       |             标高自动标注软件                 |
;;;       |         版本: V4.0   作者: 张越 (99.7.9-29)  |
;;;       |         修改于2000.6                         |
(defun C:bg (/           dx         dy    dx1   dx2   dy1         pt    txt   txt2
             oldsty         lay   pt1   pt2   pt3         pt4   pt5   ptt
             sc1   sc2
  (defun insbg ()
                                        ; (grread)
    (command "insert" "bg" pause "" "")
  (setvar "CMDECHO" 0)
  (setq lay (getvar "clayer"))
  (command "color" "bylayer")
  (if (= nil (tblsearch "layer" "wz"))
    (command "layer" "m" "wz" "c" "7" "" "")
  (if (= nil (tblsearch "layer" "bg"))
    (command "layer" "m" "bg" "c" "9" "" "")
  (if (not ztsc)
      (alert
        "    您还没有进行必要的设置\n工作,请先使用“sbg”命令。\n祝您工作愉快!\n\n
----------------作者:张越"
      (exit)
  (setq sc1 (atoi tzsc))
  (setq sc2 (/ (atof ztsc) 100))
  (setq os (getvar "osmode"))
  (setvar "osmode" 547)
  (if (= ym1 "1")
      (setq obline (car (entsel "请选择一条基准线")))
      (command "ucs" "OB" obline)
  (setq pt (getpoint "\n插入点: "))
  (setvar "osmode" 0)
  (setq orth (getvar "orthomode"))
  (setvar "orthomode" 0)
  (setq ang (getangle pt "\n方向 <用鼠标指取,直接回车为右上>:"))
  (if (= ang nil)
    (setq ang 0.5)
  (setvar "orthomode" orth)
  (if (= ssbg nil)
    (setq ssbg1 0.000)
    (setq ssbg1 (atof ssbg))
  (if (= yn1 "1")
      (prompt "\n输入标高值<")
      (prompt bgz1)
      (setq txt2 (getstring ">"))
      (if (= txt2 "")
        (setq txt2 bgz1)
        (setq bgz1 txt2)
      (if (or (= txt2 "0") (= txt2 "0.000"))
        (setq txt2 "%%1290.000")
      (if (= opt nil)
          (setq opt pt)
          (setq ypt (cadr opt))
          (setq xpt (car opt))
      (setq dy (- (cadr pt) ypt))
      (setq txt (+ (* (/ dy (* sc1 10)) sc2) ssbg1))
      (setq txt2 (rtos txt 2 3))
      (if (or (= txt2 "0.000") (= txt2 "0"))
  (setq pt1 (polar pt 3.14159 (* 6 sc1)))
  (setq pt2 (polar pt 0 (* 3 sc1)))
  (setvar "clayer" "bg")
  (if (= yt1 "1")
    (command "line" pt1 pt2 "")
  (if (/= sty0 nil)
    (setvar "textstyle" sty0)
  (cond
    ((and (> ang 0)
          (< ang (/ pi 2))
     (setq pt4 (polar pt 0.785398 (* 3.5 sc1)))
     (setq pt3 (polar pt 2.356194 (* 3.5 sc1)))
     (setq pt5 (polar pt3 0 (* 15 sc1)))
     (setq ptt (polar pt5 2.094395 (* 1.1547 sc1)))
     (setq high (* 3 sc1))
     (setvar "clayer" "wz")
     (command "text" "r" ptt high "0" txt2)
    ((and (> ang 4.88691)
          (< ang 6.283185)
     (setq pt4 (polar pt 5.497787 (* 3.5 sc1)))
     (setq pt3 (polar pt 3.926991 (* 3.5 sc1)))
     (setq ptt (polar pt5 4.188790 (* 1.1547 sc1)))
     (command "text" "tr" ptt high "0" txt2)
    ((and (> ang (/ pi 2))
          (< ang pi)
     (setq pt3 (polar pt 0.785398 (* 3.5 sc1)))
     (setq pt4 (polar pt 2.356194 (* 3.5 sc1)))
     (setq pt5 (polar pt3 pi (* 15 sc1)))
     (setq ptt (polar pt5 1.047198 (* 1.1547 sc1)))
     (command "text" ptt high "0" txt2)
    ((and (> ang 3.141593)
          (< ang 4.886922)
     (setq pt4 (polar pt 3.926991 (* 3.5 sc1)))
     (setq pt3 (polar pt 5.497787 (* 3.5 sc1)))
     (setq ptt (polar pt5 5.325988 (* 1.1547 sc1)))
     (command "text" "tl" ptt high "0" txt2)
  (setq ww (getvar "plinewid"))
  (setvar "plinewid" 0)
  (command "pline" pt4 pt pt3 pt5 "")
  (setvar "plinewid" ww)
  (setvar "clayer" lay)
  (setvar "osmode" os)
  (IF (= ym1 "1")
    (COMMAND "UCS" "")
;;;;;              初始值设置
(defun c:sbg (/ whet_next dia_id sty_zh opt osan)
  (defun style ()
    (setq n (atoi (get_tile "styl")))
    (setq sty (nth n stytab))
    (setq sty0 sty)
    (set_tile "csty" sty)
(defun fdzx (/ sty1 sty2 first tab sm1 sm2)
  (setq first T)
  (setq tab '())
  (setq stytab '())
  (setq sty_zh '())
  (while (setq sty1 (tblnext "style" first)) ;搜索图中字型
    (if        (= first T)
      (setq first nil)
    (if        (/= sty1 nil)
        (setq tab (cons sty1 tab))
        (setq sty1 (nth 0 tab))
        (setq sty2 (dxf 2 sty1))        ;字型名称
        (setq sm1 (dxf 3 sty1))                ;所用小字体文件的名称
        (setq sm2 (dxf 4 sty1))                ;所用大字体文件的名称
        (setq stytab (cons sty2 stytab))
        (if (and sm2 (/= sm2 ""))
          (setq sty_zh (cons (strcat sty2 " : < " sm1 " , " sm2 " >") sty_zh))
          (setq sty_zh (cons (strcat sty2 " : < " sm1 " >") sty_zh))
  (defun bgzh ()
    (setq yn1 (get_tile "yn"))
    (if        (= yn1 "1")
        (mode_tile "pick" 1)
        (mode_tile "ssbg" 1)
        (mode_tile "bgz" 0)
        (mode_tile "pick" 0)
        (mode_tile "ssbg" 0)
        (mode_tile "bgz" 1)
  (defun shuo ()
    (if        (not (new_dialog "shuoming" dia_id))
      (exit)
    (action_tile "shuom1" "(shuo1)")
    (action_tile "shuom2" "(shuo2)")
    (action_tile "shuom3" "(shuo3)")
    (action_tile "shuom4" "(shuo4)")
    (action_tile "shuom5" "(shuo5)")
    (action_tile "shuom6" "(shuo6)")
    (action_tile "accept" "(done_dialog 6)")
    (start_dialog)
  (defun shuo1 ()
    (if        (not (new_dialog "shuom1" dia_id))
      (exit)
    (start_dialog)
  (defun shuo2 ()
    (if        (not (new_dialog "shuom2" dia_id))
      (exit)
    (start_dialog)
  (defun shuo3 ()
    (if        (not (new_dialog "shuom3" dia_id))
      (exit)
    (start_dialog)
  (defun shuo4 ()
    (if        (not (new_dialog "shuom4" dia_id))
      (exit)
    (start_dialog)
  (defun shuo5 ()
    (if        (not (new_dialog "shuom5" dia_id))
      (exit)
    (start_dialog)
  (defun shuo6 ()
    (if        (not (new_dialog "shuom6" dia_id))
      (exit)
    (start_dialog)
  (fdzx)
  (setq sty0 (getvar "textstyle"))
  (setq oldsty sty0)
  (setq whet_next 6)
  (if (and (not dia_id) (< (setq dia_id (load_dialog "bg")) 0))
    (exit)
  (while (< 2 whet_next)
    (if        (not (new_dialog "bg" dia_id))
      (exit)
    (if        (= ssbg nil)
      (set_tile "ssbg" "0.000")
      (set_tile "ssbg" ssbg)
    (if        (= ztsc nil)
        (set_tile "scale1" "100")
        (setq ztsc "100")
      (set_tile "scale1" ztsc)
    (if        (= tzsc nil)
        (set_tile "scale2" "100")
        (setq tzsc "100")
      (set_tile "scale2" tzsc)
    (if        (= yn1 nil)
      (set_tile "yn" "0")
      (set_tile "yn" yn1)
    (if        (= yn1 "1")
        (mode_tile "bgz" 0)
    (if        (= yt1 nil)
      (set_tile "yt" "0")
      (set_tile "yt" yt1)
    (if        (= ym1 nil)
      (set_tile "ym" "0")
      (set_tile "ym" ym1)
    (if        (= bgz1 nil)
        (set_tile "bgz" "0.000")
        (setq bgz1 "0.000")
      (set_tile "bgz" bgz1)
    (action_tile "pick" "(done_dialog 4)")
    (action_tile "ssbg" "(setq ssbg $value)")
    (action_tile "yn" "(bgzh)")
    (ACTION_TILE "yt" "(SETQ yt1 $VALUE)")
    (ACTION_TILE "ym" "(setq ym1 $VALUE)")
    (action_tile "bgz" "(setq bgz1 $value)")
    (action_tile "scale1" "(setq ztsc $value)")
    (action_tile "scale2" "(setq tzsc $value)")
    (start_list "styl")                        ;字型列表
    (mapcar 'add_list sty_zh)
    (end_list)
    (setq n (- (length stytab) (length (member sty0 stytab))))
    (set_tile "styl" (itoa n))                ;聚焦在所用字型上
    (action_tile "styl" "(style)")
    (if        (= sty nil)
      (set_tile "csty" sty0)
    (action_tile "shuoming" "(shuo)")
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "cancel" "(unload_dialog dia_id)")
                                        ;(action_tile "erase" "(done_dialog 0)(setq ztsc nil)
                                        ;                     (setq tzsc nil)(setq ypt nil)(setq xpt nil)")
    (setq whet_next (start_dialog))
    (if        (/= sty nil)
      (setvar "textstyle" sty)
    (if        (= whet_next 4)
        (setq osan (getvar "osmode"))
        (setvar "osmode" 512)
        (setq opt (getpoint "\n选择基准点:"))
        (setvar "osmode" osan)
参与人数 1金钱 +50 收起 理由
gbhsu + 50 赞一个!
发表于 2023-2-11 09:22:00 | 显示全部楼层
非常不错的代码,谢谢楼主分享啊。
发表于 2018-3-23 12:03:08 | 显示全部楼层
感觉很好用
发表于 2002-12-22 14:34:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2002-12-22 14:51:00 | 显示全部楼层
不会吧,我用得好好的呀。可能是你的路径不通
发表于 2002-12-23 09:21:00 | 显示全部楼层
有个问题
程序执行到这一行出错:
错误原因:找不到DXF函数。
你的程序中确实找不到(defun:dxf()之类的定义人,是否你在其它文件中定义了该函数?
大致浏览了你的源程序,感觉不错。
 楼主| 发表于 2002-12-23 12:18:00 | 显示全部楼层
是的是的,谢谢你,我现在加上去。
dxf.lsp内容如下:
(defun dxf (code elist)
  (cdr (assoc code elist))
不好意思啊。
发表于 2004-2-6 16:34:00 | 显示全部楼层
[建议]好东西哦,不知道有没有vba的?
好东西哦,不知道有没有[U]vba[/U]的?
发表于 2004-2-6 21:12:00 | 显示全部楼层
如果觉得好,就改成VBA的吧
如果觉得好,就改成VBA的吧!
发表于 2004-2-7 19:40:00 | 显示全部楼层
我不懂vlisp,只懂点vba,哪位好心人给转化一下吧,版主有兴趣吗?
发表于 2004-3-26 16:25:00 | 显示全部楼层
5F的怎样加到1F,加进去后,appLoad "bg.lsp" command: bg, 但提示:未设比例
command: sbg 但提示:未设比例
发表于 2011-7-29 17:47:57 | 显示全部楼层
感谢zhynt楼主分享程序,<谢谢!>
GMT+8, 2025-5-24 11:48 , Processed in 0.204182 second(s), 29 queries , Gzip On.
