查看: 13039|回复: 59
AutoCAD2007明年发布,主要功能是支持64位CPU和UNICODE。
发表于 2005-7-21 17:10:00 | 显示全部楼层 |阅读模式
Unicode
VC8
Preparing for 64 Bit
Multicore processors
ATIL
Migration and CUI Customization
.NET / Windows Forms
Unicode support
Customers sharing data across continents
AutoCAD was localized a long time ago
­But current solution has limitations
Unicode is the standard now
­It addresses most data input issues
Multi-language support throughout the product
­Customers just enjoy the benefits
­Developers need to port software or add string conversion layer
char type to contain character data
Strings is typically defined using a char* or a char[]
Unicode character data g requires use of the wchar_t
Strings are typically wchar_t* pointers or wchar_t[] arrays.
wchar_t is the ANSI C++ standard keyword for the Unicode type.
wchar_t is a 16-bit value in Visual C++, roughly equivalent to an unsigned short.
§Use the /Wp64 compile switch
§Or set “Detect 64-bit Portability Issues’ to Yes in all build configurations in vcproj files.
Windows Longhorn Technologies
Biggest change since DOS to Windows
­Windows Future Storage (WinFS) is out of Longhorn
­Longhorn UI will work on Windows XP as well
.NET and managed code:
­Managed code is secure, stable, easy to develop, port & install
­APIs for managed code (C# programming)
­Windows Forms UI (Layer dialog)
­Majority of AutoCAD code will remain in unmanaged C++
Next generation print path
­Easier printing/plotting
NET
Managed wrapper classes
Write programs in VB .NET and C#.
The ObjectARX managed wrapper classes include
­Selection
­Jig
­prompt support
­complete events coverage previously available only to C++ reactors
­application object model for readily discoverable access to the properties of the application, document, editor, and window objects of AutoCAD.
­.NET applications can easily create dockable palettes and tool palettes and extend tabbed dialogs.
­The geometry library includes 2D curves, and support for external references is also present.
­support for the .NET API’s moving forward.
发表于 2005-7-22 06:43:00 | 显示全部楼层
真好,64位上能看到最有用的软件了
发表于 2005-7-22 17:47:00 | 显示全部楼层
不知有没有什么别的实用功能?
发表于 2005-7-22 19:42:00 | 显示全部楼层
真不知一年一年地升级版本是为了什么……
发表于 2005-7-22 22:00:00 | 显示全部楼层
我想办奥运时一下会升到2008版本。
现在还在用2004,不赶了。
发表于 2005-7-23 00:14:00 | 显示全部楼层
软件升级是好事,支持!
不一定新版本的出来,我们就非得换啊.根据需要吧,不过搞开发的还是要及早跟上,新的acad对.net开发有更好的支持.
发表于 2005-7-27 10:01:00 | 显示全部楼层
真希望能有.net开发完整的帮助
发表于 2005-7-27 22:54:00 | 显示全部楼层
我刚刚安装上了2006,不知道哪里有相关的学习资料。。。
发表于 2005-7-28 19:38:00 | 显示全部楼层
autocad升级的太快了,2006还没熟悉过来,我们都有些无法适从了!
发表于 2005-7-29 07:56:00 | 显示全部楼层
顶顶顶!
GMT+8, 2025-5-7 13:36 , Processed in 0.209284 second(s), 30 queries , Gzip On.
