查看: 1786|回复: 1
求助:用vla-setxdata是出现错误???
发表于 2005-7-23 17:14:00 | 显示全部楼层 |阅读模式
程序如下:
         (setq startPnt(vlax-make-safearray vlax-vbDouble '(0 . 2)))
   (vlax-safearray-fill startPnt st_point)
   (setq endPnt(vlax-make-safearray vlax-vbDouble '(0 . 2)))
   (vlax-safearray-fill endPnt p3)
   (setq Line_Obj(vla-AddLine mSpace startPnt endPnt))
       (setq xtype (vlax-make-safearray vlax-vbvariant '(0 . 1)))
   (setq xdata (vlax-make-safearray vlax-vbvariant '(0 . 1)))
          (vlax-safearray-fill xtype '(1001 1000))
          (vlax-safearray-fill xdata '("loop" "loop"))
           (vla-setxdata line_obj xtype xdata)
运行后出现:错误: Automation 错误。未提供说明。
发表于 2005-7-24 00:47:00 | 显示全部楼层
改为
(setq xtype (vlax-make-safearray vlax-vbInteger '(0 . 1)))
GMT+8, 2024-11-17 19:25 , Processed in 0.163335 second(s), 26 queries , Gzip On.
