查看: 3516|回复: 5
[LISP]文字查找与替换
发表于 2005-7-26 13:12:00 | 显示全部楼层 |阅读模式
 ;;;lsp
(defun findtext(new-str origin-str seltype matype / str-pickset disc-str-x1 disc-str-x2 disc-str-name
  disc-str-layer disc-str disc-str-insertp disc-str-height pp1 pp2 pp3 pp4 pp6 k minext-list
  maxext-list maxext minext disc-str-sub disc-str-new disc-str-presub i ij iij)
  (setvar "cmdecho" 0)(setvar "OSMODE" 0)
  (COMMAND "undo" "be")
  (if (= seltype 2)
    (setq str-pickset (ssget "x" '((0 . "TEXT,MTEXT"))))
    (setq str-pickset (ssget '((0 . "TEXT,MTEXT"))))
  (princ "\n按任意键到下一处﹐右键取代﹐回车结束﹗")
  (setq i 0)
  (setq k 1)
  (setq ij 0)(setq iij 0)
  (while (and(< i (sslength str-pickset))(/= k 13))
    (if disc-str-x1 (command "erase" disc-str-x1 ""))
    (if disc-str-x2 (command "erase" disc-str-x2 ""))
    (setq disc-str-name(ssname str-pickset i))
    (setq disc-str-layer(cdr(assoc 8 (entget disc-str-name))))
    (if (= 0 (cdr(assoc 70 (entget (tblobjname "LAYER" disc-str-layer)))))
 (setq disc-ent(entget disc-str-name))
        (setq disc-str(cdr(assoc 1 (entget disc-str-name))))
        (setq flags 't)
 (cond
   ((or(= searchtype 1)(= searchtype 2))(setq pos 't))
   ((= searchtype 3)(if(= 1 matype)
            (setq pos(vl-string-search   origin-str  disc-str))
            (setq pos(vl-string-search  (strcase origin-str) (strcase disc-str)))
        (if (and flags pos(/= k 13))
    (setq flags nil)
    (setq disc-str-insertp(cdr (assoc 10 (entget disc-str-name))))
    (setq disc-str-height(cdr (assoc 40 (entget disc-str-name))))
    (setq pp1 (polar disc-str-insertp 0.785398 disc-str-height))
    (setq pp2 (polar disc-str-insertp 2.35619 disc-str-height))
    (setq pp3 (polar disc-str-insertp 3.92699 disc-str-height))
    (setq pp4 (polar disc-str-insertp 5.49779 disc-str-height))
    (command ".line" pp1 pp3 "")(setq disc-str-x1 (entlast))
    (command ".line" pp2 pp4 "")(setq disc-str-x2 (entlast))
    (command ".change" disc-str-x1 disc-str-x2 "" "p" "c" 1 "")
    (setq minext(vlax-make-safearray vlax-vbdouble '(0 . 2)))
           (setq maxext(vlax-make-safearray vlax-vbdouble '(0 . 2)))
           (vla-getboundingbox  (vlax-ename->vla-object disc-str-name) 'minext 'maxext)
           (setq  minext-list(vlax-safearray->list minext))
           (setq  maxext-list(vlax-safearray->list maxext))
    (setq pp6 (mapcar '* (mapcar '- maxext-list minext-list) '(2 2 0)))
    (command "zoom" "w" (mapcar '- minext-list pp6) (mapcar '+ maxext-list pp6))
    (setq ij (1+ ij))
    (if (= i (sslength str-pickset)) (setq k 13)(setq k (cadr (grread))))
    (if (=  k 0)
      (cond
        ((= searchtype 1)(setq disc-str-new(strcase disc-str))(setq iij (1+ iij)))
        ((= searchtype 2)(setq disc-str-new(strcase disc-str t))(setq iij (1+ iij)))
        ((= searchtype 3)
        (setq disc-str-temp disc-str)
        (setq origin-len(STRLEN origin-str))
        (setq disc-str-new "")
        (if (= 1 matype)
        (while pos
          (if (= pos 0)(setq disc-str-presub "")(setq disc-str-presub(substr disc-str 1  pos)))
          (setq disc-str-sub(substr disc-str (+ pos 1) origin-len))
          (setq disc-str(substr disc-str (+ pos origin-len 1)))
          (setq disc-str-new(strcat disc-str-new disc-str-presub new-str))
          (entmod disc-ent)
   (if (= 1 matype)
        (if (/= nil disc-str) (setq disc-str-new(strcat disc-str-new disc-str)))
      (setq disc-ent(subst (cons 1 disc-str-new) (assoc 1 (entget disc-str-name)) (entget disc-str-name)))
        (entmod disc-ent)
    (if (= 1 matype)
    (setq i(1+ i))
    (if (or(= i (sslength str-pickset))(=  k 0)(= k 13))
  (if (= ij 0) (alert "Nothing be Found!")(setq tjz-origin-str origin-str))
  (princ "\n共选择 " )(princ (sslength str-pickset))(princ  " 项﹐ 替换其中 " )(princ  iij)(princ  " 项!" )
  (prompt "\n\n**********J.Z Tang's CONTRIBUTATION**********")
  (COMMAND "undo" "e")
(defun *error* (msg)
  (if (or(= (strcase msg) "FUNCTION CANCELLED")(= (strcase msg) "CONSOLE BREAK"))
(defun c:dr3(/ dd dcl_id )
   (setq dcl_id (load_dialog "E:\\LispTool\\vlisp\\Project\\FindText"));;;这句自己改
   (new_dialog "FindText" dcl_id)
   (setq searchtype 3 seltype 2 matype 1)
   (mode_tile "str02" 0)
   (mode_tile "str02" 2)
   (if new-str (set_tile "str01" new-str))
   (if origin-str (set_tile "str02" origin-str))
   (action_tile "jz01" "(setq searchtype 1)(mode_tile \"rep\" 1)(mode_tile \"ma\" 1)")
   (action_tile "jz02" "(setq searchtype 2)(mode_tile \"rep\" 1)(mode_tile \"ma\" 1)")
   (action_tile "jz03" "(setq searchtype 3)(mode_tile \"rep\" 0)(mode_tile \"ma\" 0)(mode_tile \"str02\" 0)(mode_tile \"str02\" 2)")
   (if (= "1"(get_tile "jz03")) (progn(setq seltype 1)(setq matype 1)))
   (action_tile "sel2" "(setq seltype 1)")
   (action_tile "sel1" "(setq seltype 2)")
   (action_tile "ma1" "(setq matype 1)")
   (action_tile "ma2" "(setq matype 2)")
   (action_tile "accept" "(setq  new-str(get_tile \"str01\"))(setq origin-str (get_tile \"str02\"))(done_dialog 1)")
   (setq dd(start_dialog))
   (if (= dd 1)(findtext new-str origin-str seltype matype))
//dcl
FindText:dialog{label="查找与替换…";
  :column{
  :row{
     :boxed_radio_column{
        label="取代方式";
        :radio_button{label="转成大写";key="jz01";}
        :radio_button{label="转成小写";key="jz02";}
        :radio_button{label="替    换";key="jz03";value="1";}
     :column{
        label="取代字符";
        key="rep";
        :column{
          :edit_box{label="搜索字符:";key="str02";edit_width=20;fixed_width=true;}
          :edit_box{label="新字符串:";key="str01";edit_width=20;fixed_width=true;}
     :row{
        label="选取方式";
        key="sel";
        :radio_button{label="全选"; key="sel1";}
        :radio_button{label="手选"; key="sel2";value="1";}
        label="对搜索字符";
        key="ma";
        :radio_button{label="区分大小写";key="ma1";value="1";}
        :radio_button{label="不区分大小写";key="ma2";}
  spacer_1;
  :row{
      fixed_width = true;
      alignment = centered;
    ok_cancel;
谢谢楼主  发表于 2012-3-16 09:29
发表于 2005-7-26 13:22:00 | 显示全部楼层
find
发表于 2005-7-26 22:39:00 | 显示全部楼层
能对天正六的索引符号有用吗
发表于 2011-10-29 13:19:01 | 显示全部楼层
torcky 大师,程序替换不了啊!!!???
发表于 2011-10-29 13:40:25 | 显示全部楼层
http://bbs.mjtd.com/thread-89647-1-1.html
这个可以替换。绝对不比楼主的差
GMT+8, 2025-5-18 01:39 , Processed in 0.179613 second(s), 27 queries , Gzip On.
