查看: 1777|回复: 0
紧急求助:各位同仁们帮助看一下这段程序问题在哪里?
发表于 2005-7-28 12:48:00 | 显示全部楼层 |阅读模式
Sub ConnectLine()
Dim mySelect As AcadSelectionSet
Dim MyVal(0 To 3) As String
MyVal(0) = "8": MyVal(1) = "TbRegion": MyVal(2) = "0": MyVal(3) = "REGION"
BuildFilter fType, fDate, MyVal
Set sss = ThisDrawing.SelectionSets
On Error Resume Next
ThisDrawing.SelectionSets.Item("mySelects12").Delete
On Error GoTo ErrExit
Set myss = sss.Add("mySelects12")
myss.Select acSelectionSetAll, , , fType, fDate
Dim myExplode As Variant, En As AcadEntity
For Each En In myss
   myExplode = En.Explode
   Set mySelect = sss.Add("sRegions5")
   mySelect.AddItems myExplode   '当前选择集已经添加了对象
   '问题:为什么下一句中P提示前一个选择集合不存在
   ThisDrawing.SendCommand "_pedit" & vbCr & "M" & vbCr & "P" & vbCr & vbCr & "Y" & vbCr & "J" & vbCr & vbCr & vbCr
   mySelect.Delete
Next
Exit Sub
ErrExit:
   MsgBox Err.Description
End Sub
'创建选择集的过滤规则
Public Sub BuildFilter(typeArray As Variant, dataArray As Variant, ByVal gCodes As Variant)
Dim fType() As Integer, fData() As Variant
Dim Index As Long, i As Long
Index = LBound(gCodes) - 1
'根据gCodes的内容创建过滤数组
For i = LBound(gCodes) To UBound(gCodes) Step 2
    Index = Index + 1
    ReDim Preserve fType(0 To Index)
    ReDim Preserve fData(0 To Index)
    fType(Index) = CInt(gCodes(i))
    fData(Index) = gCodes(i + 1)
Next
'返回值
typeArray = fType
dataArray = fData
End Sub
GMT+8, 2025-5-5 06:16 , Processed in 0.138729 second(s), 23 queries , Gzip On.
