(defun wf( / pp aa bp deci xx yy d1 k) (setq pp (getstring"\n input the name of file")) (setq aa (open pp "w")) (setq deci (getint "\n保留小数位数")) (setq deci (if deci deci 3)) (setq bp (getPOINT"\NpLEASE SELECT POINT TO WRITE OUT!")) (SETQ K 1) (WHILE BP (setq XX (CAR BP)) (SETQ YY (CADR BP)) (setq d1 (strcat (ITOA K) "," (RTOS XX 2 deci) "," (RTOS YY 2 deci))) (write-line d1 aa) (setq bp (getPOINT"\NpLEASE SELECT POINT TO WRITE OUT!")) (SETQ K (1+ K)) ) (close aa) )
;文件aa的路径能象GETFILED选择文件那样对话框指定路径SAVE吗? |
