查看: 1646|回复: 3
rand()函数要怎样写
发表于 2005-7-29 15:40:00 | 显示全部楼层 |阅读模式
请问,如果我要写一个带参数的随机函数如: random(10) 则返回从0 - 10 之间的随机数,请问要怎样写呢,谢谢
 楼主| 发表于 2005-7-29 18:08:00 | 显示全部楼层
是没人知道吗,还是各位大虾不屑指教?
发表于 2005-7-30 16:41:00 | 显示全部楼层
The rand function returns a pseudorandom integer in the range 0 to RAND_MAX. Use the ivt:vccore/F3F/F43/D4D/S4CF68.HTM" target="_blank" >srand function to seed the pseudorandom-number generator before calling rand.
Example
/* RAND.C: This program seeds the random-number generator
 * with the time, then displays 10 random integers.
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
void main( void )
   int i;
   /* Seed the random-number generator with current time so that
    * the numbers will be different every time we run.
   srand( (unsigned)time( NULL ) );
   /* Display 10 numbers. */
   for( i = 0;   i < 10;i++ )
      printf( "  %6d\n", rand() );
Output
6929
    8026
   21987
   30734
   20587
    6699
   22034
   25051
    7988
   10104
发表于 2005-7-31 12:08:00 | 显示全部楼层
函数定义
int randBetween(int numL, int numH)
 int a;
 double b;
 int c;
 if (numL > numH) //交换
  int tmp;
  tmp = numH;
  numH = numL;
  numL = tmp;
 do
  a = rand();  //产生0到RAND_MAX之间的随机数
  b = a / sqrt(a + 1);
  c = (int)b;
  if (numL <= c && c <= numH)
   return c;
 } while(1);
函数调用
void Hello()
 int nRan = randBetween(10, 20);
 ads_printf("\n 随机数= %d", nRan);
GMT+8, 2025-5-14 13:52 , Processed in 0.160893 second(s), 23 queries , Gzip On.
