查看: 1370|回复: 2
请教!!!!!!!!!!!!!!
发表于 2005-7-31 15:44:00 | 显示全部楼层 |阅读模式
请教measure与divide在lisp中调用参数,(command "measure" ???????)
发表于 2005-8-1 18:33:00 | 显示全部楼层
在COMMAND下输入该命令就可以看到,去lisp版块吧
 楼主| 发表于 2005-8-1 19:18:00 | 显示全部楼层
Private Sub div()
  Dim obj As AcadObject
  Dim basept As Variant
  Dim SSETS As AcadSelectionSet
On Error Resume Next
  If Not IsNull(ThisDrawing.SelectionSets.Item("PLSET")) Then
     Set SSETS = ThisDrawing.SelectionSets.Item("PLSET")
     SSETS.Delete
  End If
  Set SSETS = ThisDrawing.SelectionSets.Add("PLSET")
    SSETS.SelectOnScreen
  Set obj = SSETS.Item(0)
 ' ThisDrawing.Utility.GetEntity obj, basept, "please pickt pl:"
  MsgBox obj.ObjectName
'请教下一句怎样改才可以完成measure的任务?
  ThisDrawing.SendCommand "MEASURE" & vbCr & "P" & vbCr & "6" & vbCr
End Sub
谢谢赐教
GMT+8, 2025-5-5 07:00 , Processed in 0.190366 second(s), 23 queries , Gzip On.
