查看: 2008|回复: 1
请问如何使用AutoLISP在AutoCAD上开启新档案
发表于 2005-8-3 17:32:00 | 显示全部楼层 |阅读模式
请问如何使用AutoLISPAutoCAD上开启新档案,本来以为使用(command "new")就可以实现这个功能,可是会出现错误讯息。请问该怎么作才好?
发表于 2005-8-3 23:38:00 | 显示全部楼层
[I]just an info form net[/I]
Dave,
I got this code from here, some time ago, it works great. You need to preload the
LISP befor use the button.
Here is my toolbar button:
C^C(AE_NEWDWG "C:/HOME/ACAD2000/Mytemplate.d-wt" T);
for MDI only
and the code:
 (defun AE_NEWDWG ( template status / ae-acad-object newdwg )
    (vl-load-com)
    (setq ae-acad-object (vlax-get-acad-object))
    (if (not template)
      (setq newdwg (vla-add (vla-get-documents ae-acad-object)))
      (setq newdwg (vla-add (vla-get-documents ae-acad-object) template))
    (if (not status)
      (princ "\nNew drawing created\n")
      (vla-put-activedocument ae-acad-object newdwg)
Cheers,
Louis
GMT+8, 2024-11-17 21:34 , Processed in 0.161358 second(s), 25 queries , Gzip On.
