查看: 2254|回复: 0
问:为什么这个命令调用不了?
发表于 2005-8-7 11:54:00 | 显示全部楼层 |阅读模式
当对CommandMethod属性采用四个参数调用时,在AutoCAD2006中无法调用,代码如下:
using System ;
using Autodesk.AutoCAD.Runtime ;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
[assembly: CommandClass(typeof(ClassLibrary.LSMClass))]
namespace ClassLibrary
 /// <summary>
 /// Summary description for LSMClass.
 /// </summary>
 public class LSMClass
  public LSMClass()
  // Define Command "AsdkCmd1"
  [CommandMethod("Hello","Hello","Hello",CommandFlags.Session)]
  static public void test() // This method can have any name
   Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
   ed.WriteMessage("\nHello World");   // Put your command code here
个中缘由,请大家助我!
谢谢!
GMT+8, 2025-10-15 04:11 , Processed in 0.127401 second(s), 24 queries , Gzip On.
