查看: 1491|回复: 2
[求助]想知道算法,但不懂lisp,在线请高手解释一下
发表于 2005-8-7 17:55:00 | 显示全部楼层 |阅读模式
是一个地学方面的小工具,不懂lisp请高手解释或者是翻译
(defun C:cip(/ kkp R qx qxp qjp qj pt1 pt2 pt3)
  (setq kkp (getpoint "输入绘图基点:"))
  (setq R (getreal "输入吴氏网半径:"))
  (command "circle" kkp R)
  (command "line" (polar kkp (/ pi 2) R) (polar kkp (/ PI 2) (+ R 1.5)) "")
  (command "line" (polar kkp pi R) (polar kkp PI (+ R 1.5)) "")
  (command "line" (polar kkp (* pi 1.5) R) (polar kkp (* PI 1.5) (+ R 1.5)) "")
  (command "line" (polar kkp 0 R) (polar kkp 0 (+ R 1.5)) "")
  (command "text" (polar kkp (/ PI 2) (+ R 3)) "3" "0" "N")
  (command "text" (polar kkp PI (+ R 6)) "3" "0" "W")
  (command "text" (polar kkp (* PI 1.5) (+ R 6)) "3" "0" "S")
  (command "text" (polar kkp 0 (+ R 3)) "3" "0" "E")
  (command "line" (polar kkp 0 -1) (polar kkp 0 1) "")
  (command "line" (polar kkp (/ pi 2) -1) (polar kkp (/ pi 2) 1) "")
  (command "text" (polar kkp 0 3) "3" "0" "O")
  (setq qxp (getreal "输入结构面倾向:"))
  (if (= qxp nil) (exit))
  (setq qx (/ (* (- 90 qxp) PI) 180))
  (setq qjp (getreal "输入结构面倾角:"))
  (setq qj (/ (* qjp PI) 180))
 (while (/= qxp nil)
  (setq pt1 (polar kkp (- qx (/ PI 2)) R))
  (setq pt3 (polar kkp (+ qx (/ PI 2)) R))
  (setq pt2 (polar kkp (+ qx PI) (* R (/ (sin (/ (- (/ pi 2) qj) 2)) (cos (/ (- (/ pi 2) qj) 2))))))
  (command "arc" pt1 pt2 pt3)
  (command "text" (polar pt2 0 3) "2" "0" (strcat (rtos qxp 2 0) "%%d" "<" (rtos qjp 2 0) "%%d"))
发表于 2005-8-7 20:36:00 | 显示全部楼层
吴氏网分上半求和下半球,就像我们平时看到的地球仪一样,之一这个算法很简单哦!去看看成都理工大学(原地院)的构造地质学教程就知道了!
 楼主| 发表于 2005-8-7 22:16:00 | 显示全部楼层
原来是你啊,我是yxp,今天突发奇想,我想用vb来搞一下,但不知道算法,找到一个lisp的,无奈看不懂。你说的教程看不到啊,或者你解释给我好了
GMT+8, 2025-2-19 06:01 , Processed in 0.138080 second(s), 25 queries , Gzip On.
